Hey guys. Got a problem with my ac/heater control. The fan switch works fine, as does the inside/outside lever, and the middle lever (ac vs heat? I can't remember). The bottom lever, which controls the temp, is what is acting weird. When I move it from cold to hot, it will physically go all the way to heat, but it won't stay there. It comes back to the middle, which doesn't really give any heat/hot air. I'm thinking the cable may be messed up, or is this a flap in the box issue? I can move the lever over, and it feels like it wants to stay, but as soon as I let off, it goes to the middle. Any ideas?
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
![]() Join Date: May 2010
Re: AC/Heater control question
Mine has always, since new, acted just as yours does. I do, however, get full heat when to the right and ambient temp. air when to the left.
mine goes back some to but not to middle. if your not getting any heat check the flap and check your water valve to make sure it is opening.
