Old 12-18-2012, 02:50 PM   #1
68gmsee
Active Member
68gmsee's Avatar
cChevy 250 upper radiator hose too close to p.s. pulley
I was adjusting my p.s. belt on my 68 GMC six and notice that the hose is closer to the pulley than it used to be. A little too close for comfort.
It may be the new pulley I just put on the pump but for the ones that have a 250 with power steering, what year upper radiator hose are you using?
I'd like a little more clearance and the hose is getting somewhat old.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-18-2012, 07:55 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: cChevy 250 upper radiator hose too close to p.s. pulley
No one?
I guess I'll go to NAPA tomorrow and see what their hose looks like and report back.
Here's how close the hose is now. Almost touching and when I accidentally touched the hose while it was running left a cut on it.
06 Trailblazer
Old 12-18-2012, 09:11 PM   #3
pritch
pritch's Avatar
Will a slightly shorter belt help?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 12-18-2012, 09:28 PM   #4
NC67Chev
NC67Chev's Avatar
It certainly looks like yours is a lot closer than mine is. I replaced my hose a few years ago with one that looks like this:
http://www.classicparts.com/1967-72-.../#.UNEV45G9KSM
I actually got it from Autozone or Napa one, but it looks to be the same. It sits above and in front of the pulley with plenty of clearance. I can take a picture of it if it will be helpful.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 12-18-2012, 09:34 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
You can gain so more clearance if you loosen the hose clamp at the radiator and twist the hose. Then tighten the clamp while you are holding the hose in a better position. Just make sure not to kink it.
Sounds like you need a new hose any way but try this with the new one if you need more clearance.
TBONE1964 is offline   Reply With Quote
Old 12-18-2012, 10:36 PM   #6
cubber
I had a stainless hose, and could bend it however I needed to.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 12-19-2012, 01:13 AM   #7
70blackfish
I just installed new hoses and power steering and its not that close.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 12-19-2012, 09:54 AM   #8
68gmsee
Active Member
68gmsee's Avatar
I've done the twisting at the radiator and tried twisting at the t-stat housing and it didn't help. I could try a shorter belt but it's pretty close to the adjusting limit as it is and I would rather have a little more clearance on top.
The hose that 70blackfish has pictured is closer to what I'm looking for so I'll see if the one at NAPA gives me more clearance.
06 Trailblazer
Old 12-19-2012, 06:58 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Update in case any one else has a hose that's too close to the power steering pump. The NAPA hose I got has plenty of clearance. Part number is 7297 cut to fit. Looks close to the one that NC67Chev mentioned.
I had to cut about 2 inches at the t-stat housing end.
06 Trailblazer
