12-18-2012, 11:31 PM | #1 |
Front end weight
Any suggestions on front springs I need? Mustang II front end. Overall weight should be in the 3500 lb area with a aluminum headed bbc.
Posted via Mobile Device |
12-18-2012, 11:44 PM | #2 |
Re: Front end weight
A lot more info would help. But unless you have done a lot to lighten the truck 3800-3900 sounds more likely. If you are not running A/C your front weight is probably going to be about the same as a A/C small block truck. Match up to the stock small block A/C springs capacity and rate and you should be in the ball park.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
