Old 12-19-2012, 03:32 AM   #1
JWright3632
Talking 53 3100 5 window/s10 swap
Well Ive gotten enough info off of this forum to start my own build so here we go. So far my plans are simple on this one just to get it running, driving and stopping. Plans are for a 383/400 combo with a rowdy cammed, steel headed smallblock. Some 20/22 staggered wheels. Stay tuned.
Measure Twice, Cut Once Saves Lives!!!!
JWright3632 is offline   Reply With Quote
Old 12-19-2012, 03:41 AM   #2
JWright3632
Re: 53 3100 5 window/s10 swap
This is what Ive got going on so far. Getting read to build the mounts and get the cab secured, then start on the front sheetmetal. Got the wheels where I want like them, centered the cab. Need to shorten the radiator support. And yes this is just a mock up cab, its beyond hammered....
Old 12-19-2012, 04:45 AM   #3
Jyman
your cab does not look that bad, and looks like you have a good start so far.
1948 Chevy
305, NV3500, 3.73 rear, sitting on a 95 s10 frame. Still in the works
2000 Chevy Extreme lowrider, 4.3, NV3500, 3.08 rear, upgraded/modded
2001 GMC Sonoma Zr2, 4.3, NV3500, Stock
Jyman is offline   Reply With Quote
Old 12-19-2012, 05:30 AM   #4
JWright3632
It doesnt look bad, but its really not worth fixing. Sometime in its life it was hit on the left rear of the cab, and the owner tried to beat it back out but he messed it up pretty bad. the door jamb is off pretty good. The floor on the pass side is ate out so bad its made the cab support weak. I can fix it, and probably will but its gonna take some time lol. Im more than likely gonna just cut the whole thing out and bend up my own floor and a trans tunnel. Cause its gonna eventually be channeled over the frame. Im in desperate need of a bed box, I got rear fenders but no box......
Old 12-19-2012, 05:32 AM   #5
JWright3632
I like your choice of transmissions, what did it come out of?
Old 12-19-2012, 05:38 AM   #6
JWright3632
Anyone ever considered re using the factory rear mounts for the cab???? Its looks like I can possibly make it work fairly easy and I got a killer Idea on how to make it look better....
Old 12-19-2012, 05:58 AM   #7
JWright3632
The Stroker Motor, with a few goodies thats going in it....
Old 12-19-2012, 10:08 AM   #8
made2drag
made2drag's Avatar
im staying tuned to see the channeling! the cab looks decent from the pics. maybe you can cut the old sheetmetal the last owner messed up...hammer the door jamb back where it needs to be... then bend a peice of sheetmetal that copies the peice you cut out and also is a mirror image of the right side. seems doable and the floors...most floors need to be redone on projects anyway
made2drag is offline   Reply With Quote
Old 12-19-2012, 05:08 PM   #9
Jyman
My NV3500 5speed came out of a 2002 s10 xtreme with the 4.3 I only payed $150 for it and It only has 65,000 km (40,000 miles). after all the research I did on manual trans, the NV3500 should hold up to 300 hp at 350 ft-lbs. but on some of the other boards guys are saying they are running 400+ hp and 450 ft-lbs and that they are holding up. So for me the NV3500 was a Cheap trans to get. and really nothing beats a manual to play around in.
1948 Chevy
Old 12-20-2012, 10:39 PM   #10
JWright3632
Yeah its completely doable unless I can find a better cab for less than Ill be out in fabin hours lol Honestly its really not that bad, just wrinkled up pretty good. But yeah the jambs okay cause the door still shuts, its just off about 1.5 inch.
And yes the nv3500 is a great trans, the 93 and up are, dont ever buy a nv3500 out of a 23 and before, they are trash. The newer ones have bigger bearings, more heavy duty internals.
Old 12-28-2012, 08:41 PM   #11
gregw98
gregw98's Avatar
Looking good, I am building the same truck. You might want to slide your cab forward about an inch because one the engine and tranny are in, the truck will sit lower. As S10 suspension is supressed the front wheel will actually move toward the rear about an inch. I read that here on this site and followed that set up and it is coming out great.
gregw98 is offline   Reply With Quote
Old 12-29-2012, 08:34 PM   #12
booger1949
i dont no anybody that reuses the cab mounts that u showed use just make your mounts an drill threw the floor board an bolt them like the front ones r, i would suggest to put a piece of plate under the cab an weld it in for strength then drill threw that to bolt the cab to your new mounts
booger1949 is offline   Reply With Quote
Old 12-30-2012, 01:33 AM   #13
gregw98
gregw98's Avatar
Did ya'll hard-mount your cabs, or did you put some type of shock absorbing material in between the frame and cab?
Old 01-01-2013, 04:12 AM   #14
JWright3632
Yeah Ive seen a lot off ppl plate the floor of the cab. I just got a new job at a pretty badass place here in Plano Texas, so its gonna be a month or two before I start buying stuff for it. The current floor is ate up pretty bad, so Im kinda gonna do a whole one off floor for it with a trans tunnel. Ive seen some and I like them.
Old 01-01-2013, 03:01 PM   #15
JTRACEY
There is a guy over on Killbillet that used the original cab mount...
Here is a link to his thread so you can check it out... http://www.killbillet.com/showthread.php?t=36383
JTRACEY is offline   Reply With Quote
Old 01-02-2013, 10:58 AM   #16
geoffcalii
i just used the rubber pads between the front cab mounts and yes i did reuse my stock cab mounts on my 49/ s10. just level out the cab and drill new holes in the frame and bolt em up
geoffcalii is offline   Reply With Quote
