![]() Join Date: Sep 2006
Anybody running the Early Classic 4/6 drop kit
I am looking at putting the Early Classic 4/6 drop kit wondering if anybody has put it on if there is any problems dragging on anything. Or any other issues I need to know about.
Re: Anybody running the Early Classic 4/6 drop kit
I've run the ECE 4/6 kit on my '63 with very good results for over 10 years now. I am very happy with the ride quality and handling. I dont have the frame c-notched...just trimmed the bump stops, but rarely haul anything heavier than an ice chest. Nothing drags unless I don't pay attention to steep steps up into a parking lot.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
I just had my frame mocked up with there 4/6 kit and 1 3/8 drop blocks in the rear and everything fit well. I used a bolt in notch though because the last square body I had I flipped the rear axle and I hated the bouncing off the frame so i really didnt want that on this one. seems like a great kit though I cant wait to get it completely in stalled and the cab back on for a good eyeballing
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
A day late and $1 short...
I have a 4.5/6 drop on my 68 stepside with no real issues. I also do not have a notch, just trimmed the bump stops. If you are going to haul anything then a bolt in c-notch will give the clearance you need. Go For it!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
The absolute best drop kit in the industry!!!
I'm running a 4.5/5 drop with ECE parts and a custom made 3/4" rear block. I'll probably get a 6" rear spring later, though.
I have the ECE 4/6 on my '67 project and the drop isn't the only thing static,the whole project is! But,from what others say,they ride great,rear axle clearance is close w/o a notch,but is ok as long s you don't haul much of any weight. I'm now figuring on bags in place of coils in the rear because I don't want to hack the frame and want to haul and tow.
trucks72
I have that kit on this truck. Same as everyone else said. Trim bump stops and you will be fine. Only time I have hit anything is because of my exhaust hanging down.
![]() Join Date: Jan 2011
^^ what size rear tires?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
TOTY 2006
![]() Join Date: Dec 1999
My 67 is running that kit. I also have a factory sway bar. On bad roads, I do bottom out on the front a-arms. Also with the sway bar in factory position, I was not able to use a floorjack to lift front of truck without driving onto a 2"x 6" boards first. Aslo, bumper is low enough now to hit curb or parking lot curb stops. So, for me as a daily driver, I have to be aware of bumps and drive around them.
As for the sway bar, you can buy lowered mounts to tuck the sway bar up a little bit, but I just flipped the factory sway bar mounts and mounted the bar inside of of the sway bar frame mounts and that gave me the clearance for the floor jack again. Update: The tires I am running are 265/50/15 BFGoodrich Radial T/As on the later 15x8 truck rallys. (not too interested in 20s, I like the old school look) Last edited by John Fabris; 12-19-2012 at 04:48 PM. |
John- have you considered 20s on your 67? It would help with bottoming out ( arms higher off the ground) It looks like you have maybe 235/60 on the front now? 20s might help and really set it off
![]() Posted via Mobile Device
Thanks guys don't know yet may go with 3/5 for now so I can still use the truck. Love the drop though have to save for air bags on the rear so I can drop it and still use it.
#12 | |
Later ..
#13 |
had the 4/6 drop kit for three years and there were zero issues. then I bagged my truck..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#14 |
I'm 4/6 and don't rub on anything but the control arm on tall speed bumps. (This is avoided by going over them straight on and not at an angle.) Not to mention the truck rides great.
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#15 |
Thanks for the help trucks look awesome what are you're tire and wheel specs
Posted via Mobile Device. |
#16 |
I'm running 18 x 8 w/235 40 and 18 x 9.5 w/275 40.
#17 |
What is the backspacing
Posted via Mobile Device |
#18 |
I thought you were running a 3.5/5 drop? Did you swap to go lower?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#19 |
4.5 or 4.25 Front
5.25 Rear AND...I"m running 1/4 inch spacer all the way around. (Picture above is without the spacer)
#20 |
I was at 3.5/5. When I switched to 17's, it raised it some. I added a .75" spacer to the rear, but it still didn't sit right, but I dealt with it. When I put the lighter weight LS1 in, I switched to a 2" front spring.
#21 |
ECE 4/6 here and no issues.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#22 |
![]() Join Date: Jun 2011
ECE 4/6 love it.
#23 |
Wow,ECE4/6 drop,thats what i need.I was thinking the truck wouldnt sit level and i would need 4.5/6. Awesome!!
#24 |
Tot Roddin'
4.5/6" drop.... No issues.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#25 |
4.5/6 No Issues
1970 SWB Build |
