Old 12-19-2012, 11:56 AM   #1
dmw319
Exclamation CPP Shock mounting stud questions
Are these studs for the front or rear shocks? Top or bottom?
http://www.classicperform.com/Store/...ucks/CPSMS.htm
They sill a single too, what is the difference? (besides 1 versus 2 studs)
http://www.classicperform.com/Store/...uck/140357.htm
Also, how needed are these support brackets for the front shocks?
http://www.classicperform.com/Store/...k/6372FSRB.htm
Thanks yall!
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 12-20-2012, 10:55 AM   #2
dmw319
Re: CPP Shock mounting stud questions
anyone?
Old 12-28-2012, 12:40 PM   #3
dmw319
bump
Old 12-29-2012, 01:18 AM   #4
maxxxy
maxxxy's Avatar
I'm assuming this is for the truck in your signature. If so the studs are for front and rear shocks. It goes through the frame. You shouldn't need the brackets unless your frame is cracked or "wallowed-out" where the stud mounts through the frame.
We really need more info on the truck though.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
