12-19-2012, 01:27 PM | #1 |
Aftermarket Tilt Steering Column?
Im looking at swapping out the original colum in my 82 k20 with an aftermarket tilt floor shift, was wondering what length the stock column would be? here are the ones im looking at.
http://www.ebay.com/itm/360538378787...84.m1423.l2649 http://www.ebay.com/itm/261142569368...84.m1423.l2649 http://www.ebay.com/itm/360538376313...84.m1423.l2649 Any input on these would be great, thanks and happy holidays. |
12-19-2012, 02:03 PM | #2 |
Re: Aftermarket Tilt Steering Column?
These three are the same just different lengths, i just dont know what size is closest to the factory length? or if there are other columns of better quality could you let me know, thanks.
12-19-2012, 03:15 PM | #3 |
Why change the column?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-19-2012, 06:01 PM | #4 |
I guess I would rather not, but I'm going from a 700r4 to a th400 and don't like that the gears don't correspond with the shifter. But I also looked into just switching out the shifter to a 3speed, but don't know what it takes hanged the shift linkage.
Posted via Mobile Device |
12-19-2012, 09:56 PM | #5 |
Well I did the same thing but with a th350. The column will babble to shift fine with the trans just make sure that the linkage is adjusted right down near the trans. You can also take the shift plate in the dash and change it to match the 3 gears instead of the drive and overdrive symbol. Otherwise lokar does have a shifter that's either cable or mechanicle that goes on or through the floor.
12-19-2012, 10:12 PM | #6 |
So i can just change out the shift plate and then get an aftermarket linkage, or did you mean you can modify the existing linkage in some way? if this works it will be a ton cheaper and easier than getting a new column. thanks
12-19-2012, 11:11 PM | #7 |
The indicator plate on the dash can just be changed. The stock linkage will work but you will hit first on the trans before the column shifter will bottom out on the internal stop. My buds truck is the same way.
Otherwise you can buy aftermarket shifter and such and get rid of the column shifter Posted via Mobile Device
12-20-2012, 08:05 AM | #8 |
It will definitely work with your column. Just adjust your linkage and change the indicator. I did it on mine and it works just fine. Worst comes to worst, just get some linkage from a 3-speed auto truck and you'll be fine. Much easier than swapping a column.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
12-21-2012, 09:48 AM | #9 |
change out the indicator to a 3speed one, and use the correct linkage at the trans end and it will work fine.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
