Old 12-20-2012, 10:33 AM   #1
bigd65
bigd65's Avatar
rear anti-sway bar
posted on the Suburban board looking for one, but question is, has anyone ever put one on the lowered pick up. is there any PROs or CONs or is it even worth the effort. Thinking of putting one on my 87 LWB
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 12-20-2012, 02:17 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: rear anti-sway bar
Many good things. Bad thing is dont get to big of one otherwise you end with a drift truck another bad thing is its about. Two beer job so you get bored easy
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-20-2012, 03:05 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
I have a lowered 84 GMC SWB with a rear sway bar from Helwig. I installed it myself and it works well.
Frank
piecesparts is offline   Reply With Quote
Old 12-20-2012, 03:41 PM   #4
Firebirdjones
I run a rear bar on my 79 single axle 1 ton (not lowered however). I used the correct era bar for mine which uses a pair of cast iron mounting brackets that bolt to the lower leaf spring perches. Fairly robust setup. I don't believe there would be any ground clearance issues on a lowered truck really. The center of the bar doesn't hang below the center pumpkin of the 14 bolt (about 2/3 of the way down I'd say. What you do see that is noticably low are the large cast iron brackets used to mount it. Depends on how short of a tire you run as to how close that would get to the ground however.
If I have a pic I'll post it if you think that might help.
Firebirdjones is offline   Reply With Quote
Old 12-20-2012, 06:58 PM   #5
cory d
cory d's Avatar
any one know of any rear bars from other vehicals that can work? or even small front bars?
cory d is offline   Reply With Quote
Old 12-20-2012, 07:55 PM   #6
piecesparts
When I put the Helwig bar on my truck I was told by them that it would work with my lowered truck. My truck is dropped 4" in the rear with a Belltech kit. The axle is not flipped. I also run a 28.5" tire on the rear and I have never had issue with clearance. I did have some issue with the mounting of the bar ends to the frame. I chose not to use the mounting brackets that Helwig supplied and mounted my end pieces directly to the bottom of my frame rails. This set up has been on my truck since 1998.
Frank
Old 12-20-2012, 11:38 PM   #7
big10ratrod77
big10ratrod77's Avatar
Man i installed on my 79 a month or two back it was an addco 7/8 inch diameter and it made a big difference in handling, my truck had some crazy wheel hop off the line and it decreased the amount of wheel hop tremendously. i can also fly down back roads and feel safe doing so this is the second best mod I have ever installed on my truck (the first best being a front sway bar)
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 12-21-2012, 12:22 AM   #8
king-918
king-918's Avatar
Where did you get your lights?
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 12-21-2012, 08:04 AM   #9
bigd65
bigd65's Avatar
Well that's good, y'all talked me into it.
2017 Chevy Tahoe
Old 12-21-2012, 08:06 AM   #10
bigd65
bigd65's Avatar
I don't know about this two beer job thing, I can drink some beer pretty fast
2017 Chevy Tahoe
Old 12-21-2012, 09:49 AM   #11
wraprail
wraprail's Avatar
Late 70s Lincoln Mark V rear bar works well.
Clamps under housing and end links come right beside the outside of frame. I just welded a L tab. drilled a hole and done. Had stock leaf springs with lowering blocks and a couple leafs removed. Don't see why it wouldn't work on a GM rear
wraprail is offline   Reply With Quote
Old 12-21-2012, 10:19 AM   #12
bigd65
bigd65's Avatar
Maybe one a little easier to find ? Most of them have been crushed by now
2017 Chevy Tahoe
Old 12-21-2012, 02:24 PM   #13
83GMCK2500
Pretty sure one of those was just processed IN at the Wrecking Yard I work at (NOT ADVERTISING), just encouraging everyone to check out their local Yards. They are still out there. A couple months ago we processed a 30s vintage Ford F-5 or so IN with a flathead V8...haven't seen one of those in yeaaaaars up there, couple weeks ago it went through the crusher.
I have a rear sway bar on my truck, aftermarket, but my truck is stock height 4x4 soon to go up 2.5". A lot of my friends have bagged minitrucks, but given the nature of their suspension they do not have sway bars.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-21-2012, 05:54 PM   #14
G8DAN
G8DAN's Avatar
I'm running the Belltech 1 3/8 bar on my truck and it feels very balanced with the 1 1/4 bar up front. I think it is highly worth it to get a rear sway bar put on.
G8DAN is offline   Reply With Quote
Old 12-21-2012, 09:46 PM   #15
bigd65
bigd65's Avatar
Ok I'm sold, maybe just get a HELWIG or something. Need to shop around
2017 Chevy Tahoe
Old 12-22-2012, 09:12 PM   #16
bigd65
bigd65's Avatar
Ok a local wrecking yard has Two 1tons and both have REAR ANTI-SWAY BARS. BUT THEY LOOK HUMONGUS. bolt to the frame but then also to a big plate that attaches to the spring bracket. Is this to big , should I get one or just go for an after market one. The guy with probably give it to me free, he always does unless it's something big....
2017 Chevy Tahoe
Old 12-23-2012, 09:38 AM   #17
bigd65
bigd65's Avatar
Well what do y'all think, AFTER MARKET ? or get one from one of those 1tons
2017 Chevy Tahoe
Old 12-23-2012, 10:03 AM   #18
68Timber
I know the pieces fit
68Timber's Avatar
I wouldn't run one that big. gchemist mentioned the ride getting pretty stiff in his truck after installing a rear sway bar. If you add one, go conservative on the diameter.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-23-2012, 12:09 PM   #19
piecesparts
How much work are you willing to put into installing it? The lowered truck will make the install a little different that the 1-ton may have had. If you get it for free, then by all means do so and see if it will mount without pain. Otherwise go with a company that makes one to fit the lowered truck, as I did. Does the one from the salvage need new bushings or clamps, that may cost you almost as much as a new one.
Frank
Old 12-23-2012, 12:42 PM   #20
bigd65
bigd65's Avatar
It has a mounting plate on the springs, when I saw that figured it would be to big. I am probably just going to check into the after market
2017 Chevy Tahoe
Old 12-23-2012, 01:01 PM   #21
piecesparts
Look at this website for bars for your truck.
http://www.hellwigproducts.com/produ...owered-trucks/
Summit sells the bars as listed below
http://www.summitracing.com/search?k...hel-7448&dds=1
Frank
