12-20-2012, 11:18 AM | #1 |
Information on Porterbuilt front shock relocators?
2.5" spindle, and 2" spring static drop. Do I need shock relocators up front? If so .. does anyone have pictures of how they mount, specifically the PB version? If I don't need them, does anyone know a part number of a good shock to run? I will probably do KYB for now because I got a good buy on some new ones for the back. .. just so they match.
What should I put up front? KYB part number ?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
12-20-2012, 12:04 PM | #2 |
Re: Information on Porterbuilt front shock relocators?
I went with the relocates but have a lot more drop in my front end I mostly wanted to go with them becouse of the add strength vs the stock ones PB's look great I can take some pics later today of mine
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap, soon custom rear wishbone set up and bags 1942 chevy/divco ambulance 1937 chevy truck |
12-20-2012, 12:27 PM | #3 |
Do you think I even need them on 4.5" drop? Aren't they really for bagged trucks?
12-20-2012, 12:58 PM | #4 |
You might be able to get away with a shorter shock and a factory upper location.... since it's static. If it were bagged I would say go with a relocation bracket.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
12-20-2012, 01:09 PM | #5 |
Do you have pics of how they mount? Prices?
I need to call you anyway.. I need some other stuff too. Will you be around for a bit? Posted via Mobile Device
12-20-2012, 01:16 PM | #6 |
67-72 parts collector,…
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Front Shocks Doetsch Tech Shocks* DT4809G 1960-62 front Doetsch Tech Shock stock height DTM1200GLL 1960-62 front Doetsch Tech Shock lower height DT4052G 1963-72 front Doetsch Tech Shock stock height DT4809G 1963-72 front Doetsch Tech Shock 1"-2" lowered DTM1200GLL 1963-72 front Doetsch Tech Shock 3" lowered • KYB Shocks KYB "Gas-a-Just" nitrogen* KYM1200G 1960-62 front lowered KYB Shock, 2" KY4809G 1960-62 front stock KYB Shock KY4809G 1963-72 front lowered KYB Shock, 1"-2" KYM1200G 1963-72 front lowered KYB Shock, 3" KY4052G 1963-72 front stock KYB Shock* Rear Shocks KY4163G 1963-72 w/ rear leaf stock or 1" - 2" drop KY4095 1963-72 w/ rear leaf or 2" - 4" drop KY4052G 1963-72 w/ rear leaf or 5" drop KY4163G 1960-62 rear lowered* KY4231G 1960-62 rear stock KY4095 1963-72 rear lowered 2"-4" KY4052G 1963-72 rear lowered 5-1/2" KY4163G 1963-72 rear stock
12-20-2012, 01:20 PM | #7 |
Another thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=331653
12-20-2012, 01:26 PM | #8 |
Thanks Keith!
12-20-2012, 01:51 PM | #9 | |
Link: http://www.porterbuiltfabrication.co...shock-mounting
12-20-2012, 03:00 PM | #10 |
Longer shocks are usually better as they offer more travel range. Keep this in mind vs paying extra for a spec shorter 'drop' shock.
12-20-2012, 03:17 PM | #11 |
C/10 junkie
Great info on the shocks Keith
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
