![]() Join Date: Oct 2012
red interior on a 72
I amm looking to find/red door panels fir a 72 cheyenne.......Im bearing they were never made, and I will need to dye mine? Is that true? I have nev er had much luck dying panels....tbey always sem to chip or scratch and leave the previous panel color exposed. I have also heard tbe reproduction panels are low quality. Does anyone have a super nice-super clean pair of red cheyenne panels? Thanks, Greg
Posted via Mobile Device |
Re: red interior on a 72
I think the made them in red, but for some reason I want to say only on big trucks, like 2 tons. Someone else will know for sure.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Cluster King
![]() Join Date: Nov 2012
http://www.lmctruck.com/features/cb/cbc92.htm
Not sure if this is the correct color red you need. i think they are a little pricey and I would make sure they have a good return policy. I have heard mixed reviews about the quality of LMC parts. Good Luck |
Cluster King
Scratch that, after I posted above I went back and read that they are painted. You can do that yourself.
SWB 4x4 Collector
![]() Join Date: Jun 2001
They did make them. I found a set in a c/60 ex coca cola truck. They are out there. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
My Eckler's Classic Chevy Trucks catalog shows some that you have to specify color, Check the web sight www.EcklersTrucks.com Good luck.
The red door panels I have in my '72 came out of a big truck, too. I found them at a swap meet in Springfield, Mo. They are orangish, like the red paint in '72.
Thanks for the reply........since they were in a 60series....I am assuming they were not Cheyenne panels with the wood trim?
Thanks, Greg Posted via Mobile Device |
I think you could find them in the deluxe pattern ( with the scroll and SS trim ring). Then you could add the WG panels. If you find the base door pannels you can add the trim ring and the woodgrain.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Thank you for the reply. Im trying to keep my original black panels and find red panels....taalll order. If you hear or see a set, please keep me in mind. Have a nice christmas......Greg
Wide n'Low
![]() Join Date: Jan 2007
check with member Truckseats out of Tri-Cities Washington, he will know for sure, or have them already..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
