Old 12-20-2012, 01:27 PM   #1
Jimbabwe
Jimbabwe's Avatar
Getting shafted?
Guy gave me a price on the two piece driveshaft for my bagged truck of $1,000. Is this typical? It's for 2.5" steel with a corvette yoke and a dbl u-joint, if that makes much of a difference.
A few guys told me theirs were in the $500 range. My friend ordered one online for his GT500 which was a one piece, but 3" and aluminum and he said it was almost , but not quite $700.
Jimbabwe is offline   Reply With Quote
Old 12-20-2012, 01:51 PM   #2
afcamaro
afcamaro's Avatar
Re: Getting shafted?
Ive never had them cost that much. You can have your old one shortened for around $1-200. I bought a new steel offline for $250 just recently and on my camaro have a 3" aluminum for $300 awhile back. Id look around. Theres a guy on ebay that makes them to your specs and does good work for cheap. I got one from him.
afcamaro is offline   Reply With Quote
Old 12-20-2012, 01:52 PM   #3
big_al_71
big_al_71's Avatar
Way too over priced..I had mine custom built to hold up to 1000hp,
which I will never have. It cost me $250.00
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-20-2012, 02:19 PM   #4
Rochlow
If it's for your stepper with the PB suspension. I spoke to Delmo about building me a 2pc drive shaft with new carrier bearing and 2" spacer and he quoted me a price of about $700-750
I'd send him a message as he has specfic experience dealing with that suspension set up.
Rochlow is offline   Reply With Quote
Old 12-20-2012, 02:47 PM   #5
Jimbabwe
Jimbabwe's Avatar
Thanks guys.
Old 12-20-2012, 02:48 PM   #6
Jimbabwe
Jimbabwe's Avatar
Oh, and yes, it is for the stepper.
Old 12-20-2012, 02:51 PM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
If you want to drive the truck slammed the driveline angles require 2 double cardain joints on the rear shaft. Double cardain joints are expensive and shouldn't be ran at over 6* or they won't last long at all (just ask anybody with a lowered extended cab s10). They are probably just rying to cover their butt for warranty. That or they want to scare you off so they don't lose their butt on warranty.
I build driveshafts and id want quite a bit of info and to see the truck before I ever gave you a price.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-05-2013, 08:49 PM   #8
Hart_Rod
Hart_Rod's Avatar
What did u end up doing?
Hart_Rod is offline   Reply With Quote
Old 01-05-2013, 08:54 PM   #9
Jimbabwe
Jimbabwe's Avatar
Went with a different guy. Still local.
Old 01-05-2013, 08:56 PM   #10
Hart_Rod
Hart_Rod's Avatar
One or two piece? Price?
Old 01-05-2013, 09:01 PM   #11
pat 70/71
pat 70/71's Avatar
$1,000.00 is way out of line! I had one custom made for my 71 and it cost all of $225.00 with universal joints!!!! find someone else. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 01-05-2013, 09:08 PM   #12
Jimbabwe
Jimbabwe's Avatar
Two piece. 650. They didn't use my CPP carrier bearing though. I have to go to the driveline shop and get the breakdown of the joints used. My friend did the PB stuff and they figured out what to use themselves. He told me the Corvette yokes they used only fit the stock carrier bearing, and the reason they used those is because they just could not get the trans to 5 degrees. It's 6 or 6.5, and this setup will allow the greater angle with less chance of binding or vibration. (This is just what they told me) We even got different plates from PB to raise the motor but then there were other interference issues. The motor is an I6 so maybe this is less a problem than a V8. The guys at PB didn't have much experience with I6, everyone seems to go bigger, so this was just a bit more trial and error. Of course, having never done this before, I don't know if the guys doing it for me are full of it.
Old 01-05-2013, 09:17 PM   #13
Hart_Rod
Hart_Rod's Avatar
Thanks. Why couldn't they use the CCP carrier bearing? i would really like to see pics of your setup when you get a chance.
Old 01-05-2013, 09:26 PM   #14
Jimbabwe
Jimbabwe's Avatar
The opening in the CPP bearing was a different size than the joints or yokes used. He claimed they were "stock" and the CPP bearing was not. I said "So order the damned size that they are" . He said that was not possible.
Now if this were bikes, I would first of all have done all this myself, but if not, I would at least know plenty to be able to tell him he was full of it. But this is new to me, so...
Old 01-06-2013, 11:12 AM   #15
brad_man_72
the boat guy
I build driveshafts 40hrs a week. Even I won't build a shaft at home. Way too much specialized equipment involved in getting it right.
The ccp bearing is pretty (that's the only good thing I can say about them and I sell them)
The non stock stubs and yokes are cheaper and better than the original stuff.
Old 01-06-2013, 11:40 AM   #16
Jimbabwe
Jimbabwe's Avatar
I had only ordered the CPP bearing because I had read things the past couple of years on the forum where bagged guys kept mentioning how they tore the stock one apart, and the billet one stayed together. You're not going to see it, so it's not like I was thinking "Oooh, fancy"
I don't like not knowing how anything is done, so once I get the info on exactly what components were used I'll run it by you and you can tell me what you think.
Old 01-06-2013, 08:06 PM   #17
brad_man_72
the boat guy
The ccp bearing holds up better to vibration, a vibration your shaft shouldn't have. A lot of people don't want to go to a shop because they can get a carrier bearing that won't break and that "fixes" the problem for about the same money as having someone put on a new factory style bearing and ballancing the shaft.
I know what you mean about wanting to know how stuff is done. Driveshaft work is a ot more complicated than most people think, we are always cooperative when we have a customer that wants to see how its done, we like showing off our skills.
Old 07-04-2013, 11:31 AM   #18
Hart_Rod
Hart_Rod's Avatar
bump for pics!
Old 07-04-2013, 09:12 PM   #19
Jimbabwe
Jimbabwe's Avatar
Damn, that was a long time ago, but I have a couple.
Old 07-04-2013, 09:15 PM   #20
Jimbabwe
Jimbabwe's Avatar
BTW, didn't go with the "different guy" as he wound up being a flake who didn't know what to do with this truck setup, so the original crook was the only one who wanted to do it...yet, through the "friend" who was doing the suspension. That makes two crooks.
Old 07-05-2013, 01:12 PM   #21
brad_man_72
the boat guy
That double cardin setup up front cost some money for sure. Does it have a shudder at takeoff?
Old 07-05-2013, 01:57 PM   #22
tony58
Couldn't a shorty slammed be changed to a 1 piece shaft?
tony58 is offline   Reply With Quote
Old 07-05-2013, 07:54 PM   #23
brad_man_72
the boat guy
Any ride height short or lwb can be changed to a one piece as long as it doesn't hit the crossmember.
To get the driveline angles correct or run a one piece this truck would need a trans tunnel. He is avoiding the tunnel and using a two piece to go under the cab then up to the rear end.
Old 07-05-2013, 08:16 PM   #24
mgchevyparts
mgchevyparts's Avatar
Brad man, seems to me I've read on here that some of these (67-72) shortys came with 1 piece and others with 2 piece, what's up with that?
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 07-05-2013, 08:58 PM   #25
RenoKeene
Florida Edition
RenoKeene's Avatar
That is beautifully extreme and extremely beautiful. Great stepper!
This is Dynamic Engineering. It is Fluid Dynamics actually. The stress points change as revolutions increase and decrease. Add the different material densities and properties, apply heat and don't forget bind, twist and friction. This becomes science in NHRA, INDY, NASCAR, DELMO etc. Not many study this, Brad Man does and genius ain't cheap.
Sorry you got...got but you gotta go to the best to get the best, looks like your truck deserves that.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
