Let's hear/see about making a simple, (undetectable if possible), secure hood lock for our 60-66's? The simple locks for our '55 cars will not readily work on this '66 C10. In our area, it isn't uncommon to come out and find someone oogling with your hood up. Never had anyone pulling parts, but to me, I'd almost rather they fiddle with my toothbrush...
sam |
Senior Enthusiast
Re: Hood Locks
Here are some earlier threads that might prove helpful:
http://67-72chevytrucks.com/vboard/s...ight=hood+lock http://67-72chevytrucks.com/vboard/s...ight=hood+lock
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Re: Hood Locks
Thanks to Mark I have two projects with his style hood locks...cheap..simple and effective..
Thanks to Mark Bob |
Senior Enthusiast
Re: Hood Locks
Here’s a cut and paste from the links above:
Here's how I lock mine. Pretty simple and cheap. Just pop the hood and there's enough slack to lock or unlock. The bracket has a 90 degree bend that attaches under the nearest striker bolt, which is a 2" allen button head with a nyloc nut. If someone wanted to unbolt it they'd be there for a while. ![]() ![]() ![]() I had to check, it's been a long time. Seems I drilled a hole in the inner hood support panel above and behind the latch, then attached the chain with a long bolt. This allows the chain to hang in just the right location. On the other side, I double nutted the bolt, the second nut being a Nylok. Like the bolt on the grille support, it would take a long time and be very difficult to detach either connection with the lock in place. ![]() ![]()
![]() Quote:
BTW: I like the looks of your idea better than any I've seen. It's what I wanted: simple yet effective; and w/practice it can be hurriedly opened in case of under-hood fire. Hope I can return an idea some time. Sam PS: I have been having problems accessing our forum site due to an "Attack Page warning" popping up saying "this site may do harm to your computer". Can, sometimes only, access it and maybe open a post or 2, and it happens again; sometimes will not even go to site; sometimes hits as I try to submit a post--after typing up a reply. Should any others face such and are using Firefox 17, it is a problem with FF 17; go to Internet Explorer, and it has so far worked for me the latter part of today. According to a F'Fox Forum I joined just to question this problem, the new F'Fox 18 addresses and eliminates this bug and is due to debut in January. Hope this helps others. Sam |
