![]() Join Date: Nov 2010
Rear motor mount question?
I am trying to order some transmission mounts for my 65 with a crat motor and a standard 4 speed from the factory and had a question..I am replacing the ounts because it was in a wreck and i am doing a frame swap. The bellhousing was broken where it mounts to the cross member and was wondering where i get the mounts for the bellhousing? Its on both sides of the bellhousing where a bolt goes through and hada mount. any help would be great thanks
Re: Rear motor mount question?
Can you forget about the bell housing mounts and just use the side motor mounts and a cross member mount for the transmission?
Tha't what I've done on a few projects. Bob |
Cluster King
![]() Join Date: Nov 2012
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=31
I believe they are called rear engine mounts. You may be able to order these from a parts store like NAPA. I attached a link with a photo if that helps you. Good Luck |
#5 | |
![]() Quote:
sam |
