Cpp spindle confusion
Everytime I've talked to someone or researched cpp spindles I get a different answer on how they change tracking width. On my 71 parts truck I measured from rotor (wheel mounting surface) to the frame and came up with 17 7/8". When I measured on the frame in my garage I got 17 1/4". So that means these cpp spindles narrowed my track width 5/8" each side compared to stock 71 with disk brakes. My spindles are the ones that need the caliper bracket, not the ones that are cast into the spindle. Hope this helps solve confusion I know it was driving me crazy. Give or take alignment and other factors the actual measurement may differ.
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Cpp spindle confusion
Thanks for adding your comments.
![]() Join Date: Dec 2012
just read through this whole thread, i bought my cpp kit about 8 years ago and thats where i stopped working on. i just of lately started workin on this pig again and it had me worried on weather i ordered the standard or modular spindles. thx to your homework im lookin good with the modulars. thought they all where the same! good to get an idea on the BS, new wheels are in my future. great post!
So you are saying:
1) 5/8" narrower than a stock disc brake spindle. But there are still these questions,... 2) ?? narrower than a standard drop spindle? 3) ?? narrower than a drum brake spindle? The other issue with you "measuring over to the frame",... is that the angle of the lower a-arm will affect this number. (a-arm pointing down, laying flat, or pointing upward,... will change the distance to the frame)
#5 | |
BlahBlahBlah
BlahBlahBlah
I have modulars on my 71 chassis for my panel. But Its just a bare chassis (no engine/sheet metal) I can take a measurement off it if someone wants. Just need to know from where to where do you want it measured. Probably going to make more sense when the metal is hung though.
i measured from the frame to the out side of the disc "where the wheel mounts". this is with the A-arm floating and it read 17 and 1/4. i hope i have the modular spindles? any "tell tell" signs just buy lookin?
![]() Join Date: Mar 2012
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#9 | |
Thanks square 78, so with that chart says I sh
Florida Edition
![]() ![]() Join Date: Oct 2010
^What?
If you bought these 8 years ago they are not modular. If you were running drums your track width will be increased by 3/4" per side or 1-1/2" total +/- If you have a 70 or earlier rearend your front track will be 1-1/2" wider than the back. We compensate this by running wider wheels on the back. In my case I'm running 15x8's on the back and 15x7's on the front and my track width is the same from outside of tire to outside of tire. BTW the only way to get a accurate measurement is with the suspension in its operating position (preferably under load). If anyone finds this info to be incorrect please post up.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#13 |
The cpp chart showed my measurement to be within an eight of what I measured. If you measure under same conditions you should have a good reference.
#14 |
ill have check with it under load. the 8 year old drop spindle isn't sounding promising with what ive heard. i was wanting least amount of backspae as possible. anyone have a pic of their wheel on a standard spindle? would like to see how it looks. sounds like i might be buying new spindles!
