12-20-2012, 10:47 PM | #1 |
ls engine with six cylinder mounts?
I currently have a 350 sbc in the six cylinder mounts with a short shaft th350. I am going to put in a 5.3 with a 2wd 4l60e. Will the six cyl towers work or will I have to get some v8 towers? Thanks for the help.
12-21-2012, 05:51 AM | #2 |
Re: ls engine with six cylinder mounts?
I used the six frame towers on the back holes on the frame with 68 Engine mounts. It works. You will have to use a Lokar cable shifter. If you can, get it with the longer cable so it doesn't have to do a tight turn. Also, If using Doug Thorley tri-Y headers, they dump kinda close to the tranny crossmember. It makes for a tight turn coming out of the headers. Home made or custom crossmember would fix this. I used the stock crossmember and used 2 inch exhaust doing tight 90's. Also, the tranny crossmember has to be moved forward about 2 inches I think. Used the stock TH400 tranny mount if I remember correctly. Any more questions, just ask. Good luck. Jim.
12-21-2012, 04:28 PM | #3 |
hello. personally i used the v8 mounts with swaptech adapter plates. the v8 position leaves the lsx in tight space against the fire wall. i like to have space to fix anything in that general area. just my 2 cents. if you want pics pm me. good luck
01-10-2013, 01:15 PM | #4 |
Just an update, I made my own adapter plates that put the engine up three inches. The driveshaft fit perfectly and everything went in without issues.
01-10-2013, 04:08 PM | #5 |
Cool. Got it running yet?
01-10-2013, 04:14 PM | #6 |
No not yet I have to get my pcm programmed yet and figure out my exhaust.
