Old 12-20-2012, 11:24 PM   #1
desertnick69
desertnick69's Avatar
Been apart to long or bad memory?
This is a simple one what side does the heat riser go? and which wat does the arm face. This is on a 1971 C-20 w/307 and 4 speed.
desertnick69 is offline   Reply With Quote
Old 12-20-2012, 11:34 PM   #2
ole dollor
ole dollor's Avatar
Re: Been apart to long or bad memory?
i would say the right side a v-8. and not sure on the arm...c.r.s. sometimes....
ole dollor is offline   Reply With Quote
Old 12-20-2012, 11:36 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
The heat riser always goes on the driver side, and the shaft I believe is in parallel to the block.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-21-2012, 12:36 AM   #4
FirstOwner69
FirstOwner69's Avatar
Driver's side on my original 350. Here's a picture before the disassembly. I believe the passenger cars were on the right.
FirstOwner69 is offline   Reply With Quote
Old 12-21-2012, 12:44 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My K20 originally had it on the passenger side...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-21-2012, 12:52 AM   #6
FirstOwner69
Interesting. I wonder if the 4WDs had them opposite the 2WDs. Mine is a C20 and it was on the left since new. I know the manifolds are different, so it could be.
Old 12-21-2012, 01:38 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That's kinda what I was thinking. Don't know for sure, though....
- Mike -
RIP El Jay
Old 12-21-2012, 01:55 AM   #8
Gobuffalo
Gobuffalo's Avatar
First owner is correct. Lift side.
Missing from that picture is all of the heat stove tin and the tube to the manifold. That is why the heat riser is in that side.
Gobuffalo is offline   Reply With Quote
Old 12-21-2012, 02:18 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I can't recall.... but didn't the tube come up from the manifold that had the heat riser valve? I still have all the original tin, and I thought it came up from my pass. side, same side my heat riser was on before I removed it.
Edit: I know it goes to the snorkel, which in the pic above is to the driver's side. ... just thinking my snorkel may have been to the pass. side, but it's been way too many years ago for me to remember.
- Mike -
RIP El Jay
Old 12-21-2012, 03:02 AM   #10
Gobuffalo
Gobuffalo's Avatar
Look inside the air cleaner. The lower half the snorkel is attached to should be stamped with a notch. The notch would fit the shape of a Q-jet. Small blocks in these trucks used a spacer between the carb and air cleaner. The spacer should have a tab that lines up the notch. With everything lined up the snorkel should point to the left just over the alternator.
Old 12-21-2012, 03:06 AM   #11
Gobuffalo
Gobuffalo's Avatar
1973 and up the snorkel faces right and no spacer. By 1976 the was a cold air tube added that attached to core support.
Old 12-21-2012, 08:38 AM   #12
desertnick69
Thanks Stocker! This is way this ? came up to begin with! coz I just can't member! how many of you-in's have had this happen(and some a lot younger than myself)
Thanks guys for the insight. Mine goes on the drivers side, if I put it on the pass. side the exhaust pipe does not sit right.
Nick
Old 12-21-2012, 08:47 AM   #13
TBONE1964
Cluster King
TBONE1964's Avatar
It happens to me more than I like to admit. Thank god for witness marks and photos and other members trucks. I believe that the manifold that the heat riser goes to will be machined flat all the way across and if my memory (not very good) is correct, there is even a flat gasket that goes between the manifold and the heat riser. I also believe that all of the chock tubes ran through the passenger side manifold because that is the side the chock is on the carb.
And yes, it does depend on application if the heat riser is mounted on the driver or passenger side.
Hope I helped,
Merry Christmas,
Tom
TBONE1964 is offline   Reply With Quote
Old 12-21-2012, 08:53 AM   #14
TBONE1964
Cluster King
TBONE1964's Avatar
Sorry Stocker, I confused your post and thought you were talking about the small choke tube that heats the choke spring. I understand you are talking about the tin and tube that directs hot air into the air cleaner housing. With that said, I don't recall any of the 12 small block 67-72 chevy pickups I have owned being on the passenger side.
Old 12-21-2012, 09:01 PM   #15
FirstOwner69
Just to set the record straight regarding my post #4 picture...
The only thing missing from original in the picture is the heat shield above the 2 front plugs to protect the wires from the manifold heat. The heat stove and tin are not missing. It's a 69 3/4 ton and never had the stove and tube, only the PCV valve and carb collar with the hose to the flame arrestor on the right valve cover. The truck was produced in Fremont, CA, and I bought it new in Yorba Linda, CA. I seem to recall that some (all?) 1/2 tons had the heat stove on them in 69, but I'm not sure what year they actually started on the 1/2 tons. 1967-1972 was a period of rapidly changing emissions regulations, especially in California, and for a while, the higher GVWR trucks had less stringent requirements. So, what's correct for one year is not necessarily correct for every year or, for that matter, every geographic location.
Back on topic. I don't think any of this affects where the heat riser is placed. Its purpose is to force heated exhaust under the carb to speed warm-up and prevent carburetor icing. I don't believe there is any relationship with the heat stove and tube.
Jim
Old 12-22-2012, 12:20 AM   #16
thelonerife
thelonerife's Avatar
heres my 350 w a th350. Cant imagine it'd be much different on yours.
thelonerife is offline   Reply With Quote
Old 12-22-2012, 12:26 AM   #17
huahuamick
huahuamick is offline   Reply With Quote
Old 12-22-2012, 03:22 AM   #18
desertnick69
It's a bit cleaner but the same yne alt & p/s mounts the same also. Thanks
