12-21-2012, 12:44 AM | #1 |
2/3inch drop or 2/4drop ?
Have a set of 2"drop springs for the front of my 71swb.Was wondering which would give the best look3 or 4 in the rear. Not used for hauling,any help would be appriciated.Thanks Brian
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
12-21-2012, 01:15 AM | #2 |
Re: 2/3inch drop or 2/4drop ?
2/3 is be afraid of it sitting to low in the rear with a 2/4
Posted via Mobile Device |
12-21-2012, 01:21 AM | #3 |
Trucks have about a 2" rake from the factory. That is to say they are 2" higher in the rear. Do you want it to sit level or keep that rake? Do you want a slight rake? A 2/4 drop would level it. A 2/3 would leave a 1" rake. Be aware that if your truck has original springs they have probably sagged and you may be upset with the amount of lowering the new springs will offer because the amount of drop is based on the original ride height.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
12-24-2012, 01:38 PM | #4 |
Here's a picture of my truck with 2/4 drop from ECE.I also installed 5/8 lowering blocks at the rear.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, |
12-24-2012, 08:50 PM | #5 |
12-24-2012, 09:00 PM | #6 |
Whats it look like right now? What size tires are you running? Are your current springs sagged? Lots of factors to determine the stance you are going for.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
12-24-2012, 09:15 PM | #7 |
C/10 junkie
X2 we need pics of the current look.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
12-24-2012, 09:27 PM | #8 |
Thanks for all the info on 2/3 drop,I am running 275/60/15 on 8" ralleys.Hi Shawn got the front springs springs from you they look great!The original springs are on the Truck it has 76,000 orig miles on them,Brian
12-24-2012, 09:34 PM | #9 |
Here are some pics of the stock height. Posted via Mobile Device
12-24-2012, 11:30 PM | #10 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Looks like a nice project Brian.....got a soft spot for black 71 & 2's ...lol!! With a 2 inch front spring....I'd probably do a 3 inch rear, then be able to use a lowering block to fine tune to get exactly the right stance I wanted....it would be less work to fine tune with the rear lowering block than if you used a 4 inch spring, then had to fine tune with the front spring to get the stance you want, cutting a portion of a coil to get to where you want. Pretty good job to remove the front springs.
liking that 37 chevy too!! Last edited by towbar; 12-24-2012 at 11:36 PM. |
12-24-2012, 11:37 PM | #11 |
When you remove the front spring did you use a spring compressor ?thanks Brian
12-24-2012, 11:49 PM | #12 |
thanks Towbar the 37 chevy is my dads and I street rod,theres three generations of chevys in that picture just noticed that!
12-25-2012, 10:10 AM | #13 |
The tire size is P275/60R15 on 15x8in. steel rallys on all fours.Thanks
12-25-2012, 12:20 PM | #14 |
Here is the Circuit Rider ...
P245X60X15's Front P275x60c15's Rear My drop is a 2 1/2" / 4" drop.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 12-25-2012 at 06:07 PM. |
12-25-2012, 12:42 PM | #15 |
2/3 would be my choice,I think the 4 would be to low in back.Any pics of the 37? That 37 looks like a beautiful car from the fender view
Posted via Mobile Device Posted via Mobile Device |
12-25-2012, 02:15 PM | #16 |
Yea, lets see the 37.
12-25-2012, 02:18 PM | #17 |
[QUOTE=70cst;5777001]Here is the Circuit Rider ...
P245X60X15's Front P275x60c15's Rear My drop was a 2 1/2 / 4 drop. [/QUOTE What inch rims on Circuit Rider. I love the stance. |
12-25-2012, 06:04 PM | #18 | |
[quote=PAWS 72;5777162]
15x8 on all fours
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-25-2012, 09:49 PM | #19 |
70+ ( Old Skool Club )
[quote=70cst;5777458]Did you use a front dropped 2 1/2 inch spindle and 4 inch dropped spring to lower the truck? I want to do the same drop as you have but when I called ECE they said my 255/70 R15's on 15 x 8 Rallys may rub when front wheels are cranked. My tires are 29.04 inches high and I notice your fronts are 26.56high and I'm sure yours dont rub. Do you think my tires will rub? By the way love your truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-25-2012, 10:02 PM | #20 |
Stickman and Paws here are some pics of the 37 thanks Brian Posted via Mobile Device
12-25-2012, 10:04 PM | #21 | |
[quote=Already Gone;5777700]
12-25-2012, 10:31 PM | #22 |
Thanks 70cst. I can't decide if I want to lower the 71 or not.But I did get a set of sidepipes for fathers day that is going on it when I do a engine swap.
The 37 looks sweet also. |
12-25-2012, 10:33 PM | #23 |
If your undecided buy the 3" rear drop. If you dont like it make and add a 1" block. If you go with the 4" outta the gate you cant get back to 3 without a different set of springs
12-26-2012, 11:02 AM | #24 |
Just get the 4/6 and be done with it!!
In all seriousness, the 2/4 drop looks good. I think 71-72 fleetsides look better leveled out. The 2/3 drop will still have some front rake to it.
02-12-2013, 11:09 PM | #25 |
I did the 2/3 drop over the weekend and the Truck looks great very happy with results,wish it was a little lower in the rear but can tune it with lowering blocks Thanks for eveyones input Posted via Mobile Device
