Old 12-21-2012, 01:20 AM   #1
Bierkan
Bierkan's Avatar
Steering Column Options for an AD
My 50 currently has a Chevette steering column in it. It has to go.
Next spring I might be able to pull another AD column out of a truck at my favorite bone yard - he's closed after the first snow fall (we just got 10" today). However, with the '72 wiring in my frankenbeast, I need to consider a more modern ignition switch. Could be on the column or in the dash.
Just curious what fits and looks decent in these trucks. I'm currently thinking either AD or 67-72 or a cross of both (newer C10 column with a AD era steering wheel).
James "Bierkan" Vierkant
1950 3100 on a 1972 C10 Chassis
Truck Blog
Motorcycle Blog
Bierkan is offline   Reply With Quote
Old 12-21-2012, 02:43 PM   #2
mknittle
mknittle's Avatar
Re: Steering Column Options for an AD
i made mine from tubing and left over parts. it was fun too!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-21-2012, 05:56 PM   #3
63 & 64 Bowties
and a few others
http://www.speedwaymotors.com/Nostal...lumn,9145.html
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-22-2012, 12:24 AM   #4
Bierkan
Bierkan's Avatar
Didn't think of that. I could tear the Chevette column down and build a tube to house it.
Truck Blog
Motorcycle Blog
Old 12-22-2012, 06:04 AM   #5
mechanixman
mechanixman's Avatar
Hey, I'm thinking about a new column also. Mknittle, could you give some more info on making your own column?
The best thing I could think of, was to get a cheap column, remove the old plastic housing and make a new one housing out of some tubing.
mechanixman is offline   Reply With Quote
Old 12-22-2012, 01:09 PM   #6
mknittle
mknittle's Avatar
this is what I did.it all sterted with eliminating the ignition lock cyinder. after that the rest seemed pretty simple!
http://67-72chevytrucks.com/vboard/s...d.php?t=474288
Mark
My GMC build.
Old 12-22-2012, 01:30 PM   #7
Chevette
Chevette's Avatar
"It has to go". Hey! Watch what you say about Chevettes!
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 12-22-2012, 03:35 PM   #8
mknittle
mknittle's Avatar
I once saw a Chevette witha big caddy eldorao motor and transaxle in back!
Mark
My GMC build.
Old 12-23-2012, 04:10 PM   #9
Oklahoma_k5
Has anyone modified a stock column to work? I have looked at mine and thought about shortening the tube adding a sealed roller bearing at the bottom and machining the shaft to double D. Haven't measured the shaft diameter to even know if its big enough though.
Oklahoma_k5 is offline   Reply With Quote
Old 12-23-2012, 06:53 PM   #10
smittster
I believe I used one from Flaming River. It was made for the AD trucks.
smittster is offline   Reply With Quote
