Old 06-07-2003, 12:11 AM   #1
BigRed
Problems after carb install :(
I installed a new carb today on my '75 1/2 ton (350/TH350). It is a Carter 625 cfm (same as Edlebrock 1406). It was previously used but only for a short time.
After I got it in, it seemed to run fine. We took it for a test drive and I noticed it cutting out right when I would hit the throttle hard and then it would be fine. I got out on a major road and hit it hard and it was great!!! Drove fine for awhile. Then, got do an intersection and it died! Well, made it home driving with two feet and it turns out the vaccum advance hose came off the distributor. So, put that back on (gotta get a new one tomorrow) and it seemed to be ok. However, to get it started now I have to step on the throttle all the way and then have to give it gas to get it going. Then, it will run for a short time and then die. I have checked for all vacuum lines to make sure there is nothing not capped.
Questions
1. What can I check to fix the stalling problem? What could it be?
2. What can I check to fix the "cutting out" problem when I hit the throttle hard real quick?
Thanks in advance!
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 06-07-2003, 01:41 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
1. I would take the top off the carb and check the float levels. Here's a link to show you where to bend the float and instructions. http://www.edelbrock.com/automotive/...oat.html#float You need a 7/16 drill bit for clearance to measure. Make sure to have both set evenly.
2. After you have the floats set and the carb back together adjust your idle then your air inlet screws (two screws on the front). Once these are set this should help out more.
Also if when you floor it it may be getting too much fuel because of jets. I would try the floats first then if still not working you might look into a carb kit to tweak with rods and jets. They can produce more or less flow.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 06-08-2003, 12:26 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Check the plugs. You may have fouled the plugs.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-08-2003, 11:25 PM   #4
BigRed
Thanks G, that's my next is to replace the plugs. I actually got it running pretty good, but am still having a slight problem right when I hit the accelerator. It just hesitates slightly. That and I have to replace my kickdown cable.
Scott Shelbourne
