12-21-2012, 05:49 PM | #1 |
New Guy - 3 Speed manual with OD
OK, just picked this up and I have a question with regards to the 3 speed on the tree. This truck has a t-handle beneath the ignition switch with overdrive label on it. I tried to pull it, very hard. Looks like it goes to a solenoid on the trans. What does this actually do? Will this get me a 4th gear? Please help, happy with the truck, unhappy with the 3 speed trans.
12-21-2012, 07:41 PM | #2 | |
Re: New Guy - 3 Speed manual with OD
Pulled out, it is supposed to make the tranny a simple 3-speed tranny. Pushed in, it allows tranny to go into overdrive at speeds above approx. 28 mph--regardless of gear you are in--just let up on accel. when you get to about say 30mph & feel it 'shift' into its 70% RPM-reduction, or overdrive. Then speed up, if gearing/eng feel up to more speed in that gear, and if in 2nd-with-od, theeen shift into 3rd-with-od. Probably, best to shift into 3rd at speed below 28, accelerate up to about 30 or better, let off accel & feel it shift into od--at which time just give it the gas and drive on! You can also shift 1-2 and then 2-3 w/out depressing clutch, as it free-wheels when you let off the accel. at speeds below that approx. 28 mph. Be careful when parking with lever pushed in, as car will roll. Iirc, park in First? Reverse? Or pull out lever? By all means, engage handbrake. One more thing: when you begin to to pass a car, if you press accel. to floor, it jumps outta od to give you a passing gear. After passing, let off accel. & feel it go back into od, dropping RPM's about 30%. Assuming lever is not 'frozen' up, start engine and move car a few inches as you steadily pull cable out gently. Enjoy that 'best of both worlds...it pulls when you need it, and cruises when you want it' by moving to od. Good mpg on the hwy too! Sam |
12-21-2012, 09:37 PM | #3 |
Vortech:
Original 3 speed overdrive tranny is a crown jewel. Read all about it here: http://www.speedprint.com/deves50/overdriveindex.php Regards, Steve New Orleans |
12-21-2012, 10:48 PM | #4 | |
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
12-22-2012, 01:55 AM | #5 |
Thanks, need to check to make sure I have the kick down switch and relay. I do not recall a kick down switch on the carburetor. I'll let you know if I get this working. Thanks for all the help. Really good info,
12-22-2012, 05:01 AM | #6 | |
What worked nice for me: I disconnected the governor that dictated that approx 28 mph, ran wires to a 2nd dimmer switch I mounted in floor, and I could click into od at any speed and in any gear--giving od to each of 1st, 2nd, & 3rd--which gave me 6 forward gears. I could accelerate from 0 to 55 and never exceed much over idle-rpm levels. That 55 hardtop with a 250-horse 327, would go almost 22 mpg on largely-hwy trips. And with its factory 4.11 would light-to-light with some of the best. |
12-22-2012, 08:06 AM | #7 |
Momentarily killing the engine takes the loading off the gears and allows the od to shift without using the clutch. Kieth
12-22-2012, 01:35 PM | #8 |
Wire diagram would be great. I'd like to get the OD working. I did not find a kick down switch. The diagram will help me map this out. Any idea where I could find parts if I need them?
12-22-2012, 05:12 PM | #9 | |
Normally, at speeds under approx 28mph, and lever-cable pushed in, there is no "gearing down" available in ANY gear--but there IS driving force anytime you depress accelerator--that pawl is neither manually engaged by cable nor electrically engaged by solenoid, pawl, & system. When you let off the gas at these speeds, it's as if you have pushed clutch pedal in; hence the ability to shift w/o using clutch. Last edited by luvbowties; 12-22-2012 at 05:37 PM. |
12-23-2012, 02:45 AM | #10 |
great, keith Luvbowties, thanks for the help
01-31-2013, 01:28 AM | #11 |
Still trying to trouble shoot this Borg Warner with OD. Any idea what the kick down switch looks like and how it connects. I do not see anything bolted on the firewall and connected to the accelerator linkage
01-31-2013, 02:37 AM | #12 | |
HTH, Sam *pic in 2nd response is identical to one I had... Last edited by luvbowties; 01-31-2013 at 02:44 AM. Reason: ex pic |
01-31-2013, 02:43 AM | #13 |
Sam |
01-31-2013, 02:55 AM | #14 |
...a 6-volt Plymouth cct, but basics more nearly plain to see...
01-31-2013, 03:46 PM | #15 |
thanks, truck came with some extra parts. I'll check to see If I can find this
