Old 06-07-2003, 12:46 AM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Question rebuilding posi..?
whose done it? what all would it take in a truck posi with the fur springs and ltte plates?? anything othre than that set of stuff. and wat poundspring rate would a truck like this need?? it slipped a fai amountwith ET Streets on, with my burnout though he one that stuck did get hotter, but this isn't the first time I've doubted the posi unit when we cn posi pics again I got a ice smokey pic
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 06-07-2003, 10:13 AM   #2
Mike C
Mike C's Avatar
Tom's Differentials has rebuild kits. Buy a GM overhaul manual will show you how. Helps to have a pair of axles you can use to rotate spiders back into case after installing new clutch plates. Springs can be a *****. I compressed mine and wired them together, then inseted into the diff, cut the wire and worked it out with pliers.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-08-2003, 12:37 AM   #3
chevy2racr
chevy2racr's Avatar
anyoneelse?
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 06-09-2003, 11:18 PM   #4
chevy2racr
chevy2racr's Avatar
TTT???
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 06-09-2003, 11:23 PM   #5
speeddemon
speeddemon's Avatar
WHAT?
69-C10 LWB
71- fleetside shortbed
It's a shame stupidity isn't painful
Never play leapfrog with a unicorn
speeddemon is offline   Reply With Quote
Old 06-09-2003, 11:38 PM   #6
chevy2racr
chevy2racr's Avatar
at speddemon?
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 06-11-2003, 12:00 AM   #7
chevy2racr
chevy2racr's Avatar
ttt
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 06-11-2003, 03:25 PM   #8
Mike C
Mike C's Avatar
Really don't want to spend $20 on that overhaul manual, huh? Trust me, it is the BEST repair book you'll ever buy.
Shows how to R&R differentials, install ring and pinions, rebuild PS pumps, AC compressors, transmissions, etc. All of the stuff the crappy aftermarket books don't tell you.
Other than that, just take it apart and put it back together with new parts. That's how I rebuilt mine circa 1990.
44 Willys MB
52 M38A1
64 Corvette Coupe
