![]() Join Date: Dec 2008
Brake Booster mod (smaller or closer to firewall)
So what had anyone done for getting the brake booster closer to the firewall as well as shrinking the booster down to what size?
I would like to get it close as possible to the firewall rather than having it stick so far out like OEM. Any kits out there anyone recommends. Thanks |
![]() Join Date: Apr 2012
Re: Brake Booster mod (smaller or closer to firewall)
Seems some guys run just a master cylinder with no booster like a Wilwood and have no issues. Others use a smaller 8" dual diaphragm booster for more braking power.
Posted via Mobile Device |
Wide n'Low
![]() Join Date: Jan 2007
Search some threads by Delmo, I know he did a mod on a truck or two where he removed the brackets and put the booster right on the firewall
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
I found that a 73-87 booster will bolt right on to the firewall if you cut the top of the bracket off and drill 2 new holes. Looks much better to me.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
thats what I did. I had to cut the rod down some because when you throw it into park it would hit the booster and not fully engage into park.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
Oh yeah! Shifter rod needs a trim.
I am a Referee of life.
If you want power but less size,the Hydro boost looks like it would be a good choice.There is a thread on it somewhere.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
A member here used to sell a bracket that moved the stock booster closer to the firewall.
I was going to buy one, but I lost his info. Maybe someone remembers his name...?
![]() ![]() It ain't yours, if you didn't build it! |
no booster for me and the truck stops perfect...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Al you running the manual prop valve ?
yes !!!!
In that picture it does not show it since I moved it up in the engine compartment here is a more recent picture mandy..
#12 | |
#13 | |
thanks for the compliment!!
#14 | |
Collector of Projects
link HERE and a diaphragm HERE not cheap but stainless never rusts... Last edited by mcmlxix; 12-26-2012 at 01:46 AM. |
