12-22-2012, 11:20 AM | #1 |
Wood Bed Installation question
I wasn't sure where to post this question so here it gose. Dose anyone know if you have to run the mounting bolts threw the wood in the bed or can you just bolt the bed rail to the frame?
12-23-2012, 07:41 PM | #2 |
Re: Wood Bed Installation question
Anyone?
12-23-2012, 07:59 PM | #3 |
I didn't go through the wood on the blue '65. Just notched the back of the wood for the bolt heads and bolted the metal braces down. Much cleaner looking that way.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-24-2012, 09:05 AM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I didnt go through my would with the bolts.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-24-2012, 09:56 AM | #5 |
I bolted directly also, here is a pic
http://kieth.smugmug.com/Trucks/66-G...x8TPp&lb=1&s=A http://kieth.smugmug.com/Trucks/66-G...fv9bn&lb=1&s=A |
12-24-2012, 11:30 AM | #6 |
I ground out the underside of the boards and installed the bolts hidden. It works great.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb |
12-24-2012, 11:37 AM | #7 |
First of all your truck came out great! I have been working on my bed for over a month working out all the imperfections. I was on GMC Paul's site and saw that he had the specs for cutting you own boards. Did you cut your own and what stain did you use? I guess I can do the same with my stepide just use the strips to hold down the wood?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
12-24-2012, 12:02 PM | #8 |
Thanks I think thats what I will do not go thru the wood. I think it dose look cleaner. I was just wondering if the bed was not as secure with out the bolts thru the wood.
12-24-2012, 12:11 PM | #9 |
Bed install on Ol John Lee....pine from lowes, milled at home on the table saw. Only thru bolts were on the extreme left and right bed rails at the angle brackets and the four holes for bed to frame holddown.
http://67-72chevytrucks.com/vboard/s...d.php?t=548032 |
12-24-2012, 08:20 PM | #10 |
I'm just starting to install my wood I went with a balck stain. but I also sealed the 4 corner pocket holes on top of the bed and the seam on the back side of the bed. Along with the hidden hinges No chains.
