Old 12-22-2012, 03:59 PM   #1
swells6367
swells6367's Avatar
fuse box upgrade
does any one know of a fuse box upgrade to get rid of the glass fusees
Scott wells
1973 k10 81 7.2l power-train
swells6367 is offline   Reply With Quote
Old 12-22-2012, 05:07 PM   #2
donut
donut's Avatar
Re: fuse box upgrade
Don't like the glass fuses? Thought about this changeout for my old '73, but decided if I wasn't going to re-do all the wiring, why bother.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-22-2012, 09:39 PM   #3
Ziegelsteinfaust
For the complication of the job you be better off with a whole harness kit. I had a bad fuse block on a Nova from miss use, and they told me even if the wires are fine I would be happier with the whole kit. So when I flipped the fuse block over I could see they were right.
That way you can have it set up for any of the features you want later or want to add a better wiring solution for. Like HEI, AC, and a relay for the headlights
Ziegelsteinfaust is offline   Reply With Quote
Old 12-22-2012, 11:27 PM   #4
whiskeydented
whiskeydented's Avatar
I just swapped out the glass fuse block in my 78 with a bladed fuse block from a 79. I had to use the engine harness too.
whiskeydented is offline   Reply With Quote
Old 12-23-2012, 10:00 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
I'm stripping out the 88 burb, fuse box and harness ,everything inbetween.
Looking to do this to the 78, glass to blade,plus more power,and figure out the high beam and wipers might be a bonus,using 88 tilt coloum
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-23-2012, 01:45 PM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
My old 74 I put a harness from an 82 into it. Bumper to bumper. Got all the proper switch's for the 83 as well just to make sure there were no headaches during/after the swap. All plug and play. Worked like a dream for 10 years. Then I sold it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
