Old 06-07-2003, 07:46 AM   #1
Mike76251
Ft. Swaybar Poly Bushings
I notice in Summit that the poly bushings listed will not fit our Chevy Trucks.
Any idea why?
To put it better.....what brand poly bushings will work on my front swaybar?
It is a '84 "heavy-half" 1/2 ton BTW.
Thanks,
Mike
Mike76251 is offline   Reply With Quote
Old 06-07-2003, 11:33 AM   #2
sbc350gearhead
sbc350gearhead's Avatar
Jeg's lists Energy susension master kits that include the sway bar bushings for 81-87 full size trucks. They also list the bushings by themselves by size, not by application. Do you know the size?
sbc350gearhead is offline   Reply With Quote
Old 06-07-2003, 11:40 AM   #3
cdowns
cdowns's Avatar
just measure the diameter of the bar and Summit has them either from energy suspension or prothane
Old 06-07-2003, 01:18 PM   #4
SCOTI
SCOTI's Avatar
Summit has bushings for both cars & trucks ( EnergySuspension, they just list the cars). The truck bushings have more material to them & are actually larger (with larger matching brackets) than the same diameter bushing required for a car.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-09-2003, 06:20 PM   #5
COBALT
COBALT's Avatar
Look up Energy Suspensions Systems on Summit. You'll need to measure the diameter of your bar, and then look up the one you want. Yes, they'll be for truck, but I know Summit has direct replacements because that's where I got mine for my '69. I believe mine were 1 1/16".
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-10-2003, 04:03 AM   #6
Mike76251
Thanks all!
I will soon see.
