Old 12-23-2012, 04:51 AM   #1
cory d
cory d's Avatar
anyone lower their beds? (stepsides)
have any of you dropped the bed so the bottem of the step is level with the bottom of the rocker? i would have to raise the bed floor, no problem, it drops right in lol. would it work with the stock tanks? i may be ditching them for a 210 tank in the near future so that may not be a big isue.
cory d is offline   Reply With Quote
Old 12-23-2012, 05:18 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: anyone lower their beds? (stepsides)
Kinda looks like an s10 bed on a truck after that. If s10s had beds like that
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-23-2012, 10:22 AM   #3
...and the body lines and the wheel openings don't line up and the reinforcement indents show on the back of the cab? No thanks,gain one and lose three. GM got it right IMO
Old 12-23-2012, 12:23 PM   #4
Bowed
I agree , I feel it just doesn't look right .
Bowed is offline   Reply With Quote
Old 12-23-2012, 03:07 PM   #5
bigblock73
yeller
bigblock73's Avatar
Wheel wells didn't line up from the factory anyhow guys...rear was always lower
Lowered bed looks nice IMO, but the back of the cab should be smoothed..the exposed ribs have always bugged me on steppers, lowering the bed will only make them pop even more
bigblock73 is offline   Reply With Quote
Old 12-23-2012, 05:20 PM   #6
bigwheel15
bigwheel15's Avatar
Honestly the wheel wells doesn't bother me much, if the recesses on the back of the cab were smoothed out it would look perfect.
bigwheel15 is offline   Reply With Quote
Old 12-23-2012, 05:23 PM   #7
cory d
cory d's Avatar
i dont mind them on the side, it would look weird without those. i could lower the tops of them an inch or two. i think its beter to have the bottem line up then have the body line that is far away to line up. the rear wheel well is already almost 2" lower.
Old 12-23-2012, 05:45 PM   #8
Redcap
It would look dumb.
Redcap is offline   Reply With Quote
Old 12-23-2012, 06:05 PM   #9
bigwheel15
bigwheel15's Avatar
You could always lower the front wheel well opening like dv8 did to solve that problem.
Old 12-23-2012, 06:09 PM   #10
INSIDIOUS '86
If the bed was about three inches taller and the fenders raised to body line I'm sure it would look decent
Old 12-23-2012, 06:20 PM   #11
Low84
Low84's Avatar
This is something GM overlooked or was just plain sloppy when designing these trucks and it bugs me quite a bit. Doesn't look too bad on lifted step side but when lowered the gap is noticeable
I've thought about different things and the "easiest" would be to mess with the step and make it come down some to meet the bottom of the rocker and extend under the front lower portion of the fender
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 12-23-2012, 07:22 PM   #12
I have always loved GM vehicles because across the board they are the best designed and most attractive vehicles out there. Now 30+ years later guys start nitpickin' teeny details...sheesh. Stop starin' at the truck and drive it
Looks good to me:
Old 12-23-2012, 09:42 PM   #13
durty harry
durty harry's Avatar
Looks good to me:
Well said ...
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 12-23-2012, 10:50 PM   #14
Low84
Low84's Avatar
Looks good to me:
That's because you're looking at it from the top. The problem is at the bottom...
There's a difference between being brand loyal and being honest and when it comes to GM no other full-size GM body style pick up has this issue where the bottom of the bed won't come down to meet the bottom of the cab and that includes models older than 30 years
Old 12-23-2012, 11:10 PM   #15
jitteryguy
GoatLube Experss
jitteryguy's Avatar
not a step side fan so I never noticed this befor, but after look'n at the two picture's I think the orange one does look better.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-23-2012, 11:47 PM   #16
I think I know what I'm looking at after 40 years. Believe me,I've looked at them from all angles. When it comes to Ford Flaresides and Dodge Utilines there's no comparison. Their beds didn't even change to go with the body style. Ford used the same bed from 53-79 and Dodge was like 52-80s(?). Their boxes were too high,IMO. I'm honestly saying that picky little tid bit just doesn't bother me at all.
Old 12-24-2012, 12:47 AM   #17
Low84
Low84's Avatar
Which is why I said when it comes to GM. GM still has any other car maker beat hands down in this era. However GM also practically ran the same bed from 54-87 changing little else than the actual fenders.
Getting back on track as I actually own the red one and it's a real issue for me. I think the bed floor does have to be raised and I'm not sure on the stock fuel tanks if you're going to go the same route as the orange one. But as special-K mentioned you're going to hide the bottom gap from the eye and bring up the cab indents, the wheel opening is going to be lower (which many GM car bodies had), and the gas tank might have to be replaced. You start to have to factor in the trade offs and if it's worth it to you or not.
I already gave one of my ideas to alleviate this problem. I have one more, but I need to photoshop it first to see how it will look and if it's even worth bringing up.
Old 12-24-2012, 02:00 AM   #18
bigblock73
yeller
bigblock73's Avatar
Might just be easier to lower the steps down and stretch the front side of the fenders down to match
Old 12-24-2012, 02:44 AM   #19
Da88burban
GM's 4 Life
Da88burban's Avatar
Here a quick little MS paint job of a stretch I just did.(front and rear)
I never really noticed how much higher the bed sat up than the cab but I feel its not bad the way it is. I do like the stretched look tho.
Jack
'54 Chevy 3100 "Just a Mess"
'74 Chevy Super 10 468BB "One Fast Rust Bucket"
'86 Pontiac Fiero GT
'88 Chevy burb "Tha Big Turd"
'93 GMC Safari "Bone Crusher"
.................____________
.............../______l___|___\____
;,;,;,;,;,;,;|__(O)_| __l___l__(O) |
Da88burban is offline   Reply With Quote
Old 12-24-2012, 08:47 AM   #20
Stretching the panels does seem to make sense for solving this issue. I think I've seen this done on other body styles as well. I wondered about lowering these pieces,but not sure the distance to the rail would look so hot and there are a lot of mounting holes to deal with,as well as extending the front stanchion.
I think by '73 (if not '67) the Fleetsides were what the body designs were all about and the Stepsides were a carry-over for the traditionalists and to offer the cheapest base price o fleet bids. For a few it was still a preference foe easier bed access. They were more a utility bed than one for style. Not to say that in '73 there was a following for styling,just like today. It was all about the "California Stepside" back then,more than the Fleetside.
