Old 12-23-2012, 10:22 AM   #1
kevinc
kevinc's Avatar
Getting closer...
Just installed my 2002 5.3L into my 1966 C10 yesterday and I wanted to share the moment. I'm really quite proud of it and overall it went well. The only hiccup I had was the holes on the frame supports were a little too close together, so I had to redrill them about 1/4" farther apart on each side and it dropped right in. The motor mount plates I made at work on our new waterjet out of steel plate. They are the same design as these - http://www.speedwaymotors.com/LS1-Mo...FSOnPAodKQQA3Q
Now I'm off to hook up wiring and install engine accessories. I'm still figuring out what to do for fuel. You guys really helped me along by posting information and pictures of your installs.
Thanks,
Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 12-23-2012, 02:49 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Getting closer...
Looks great!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-25-2012, 01:40 AM   #3
mooseknuckles
mooseknuckles's Avatar
nice!
mooseknuckles is offline   Reply With Quote
Old 12-25-2012, 10:12 AM   #4
w4625
Purdy!!
w4625 is offline   Reply With Quote
Old 12-26-2012, 11:08 AM   #5
kevinc
kevinc's Avatar
Made a little more progress over the weekend. Installed the wiring harness and still need to hook up to power. Installed all the front accessories except the A/C compressor. It interferes with the motor mount by 2". Need to look into a hi-mount compressor bracket. Any suggestions? I got the cruize module and computer located. What have you guys done with mounting the computer?
Thanks,
Kevin C
Old 12-26-2012, 04:10 PM   #6
ls1nova71
ls1nova71's Avatar
I usually make a bracket to mount the PCM under the driver's fender, but not sure that's a possibility on the older trucks.
As for A/C brackets, there are several companies making them. The new Holley bracket looks nice. http://www.holley.com/20-131.asp Then there's Kwik Performance, http://www.kwikperf.com/lsx_ac.html and also Alan Grove, it's a more complete kit, http://www.alangrovecomponents.com/LS.htm
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-26-2012, 10:00 PM   #7
kevinc
kevinc's Avatar
Does the computer body need to be grounded?
Old 12-27-2012, 01:50 AM   #8
ls1nova71
ls1nova71's Avatar
Not the case, it is grounded in the harness, but I don't think that was your question.
Old 12-27-2012, 06:16 AM   #9
kevinc
kevinc's Avatar
Actually that was my question. I just wanted to know if the computer case itself needed grounding or not. Where did some of you put the computer? Any pictures?
THank you,
Kevin C
Old 12-27-2012, 05:20 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My computer is run way up front behind the "vent" in the rad support/shroud. It is mounted on a silicon and rubber pad and strap; its un-needed, but I like being able to pop the ecm out in 20 seconds as a theft deterrent if needed, and I was weird about metal-to-metal mounting my computer. Not the showiest setup, but I can get at everything in seconds, no "trace the wire" problems.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-27-2012, 05:28 PM   #11
DrppdBlazr
DrppdBlazr's Avatar
badass man
DrppdBlazr is offline   Reply With Quote
Old 12-28-2012, 06:12 AM   #12
kevinc
kevinc's Avatar
That's where I have my computer sitting right now, but not bolted or strapped in place yet. I figured there would be good air flow in that location. Have you had much issue with water spraying there? Where did you get the little fuse block from? Looks like a slick setup.
Old 12-28-2012, 01:21 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Never had water touch the ecm, or even come close...and it's been driven through TORRENTIAL rain (thats a long story in itself).
The little fuse block is part of my swap harness made by fuelinjectionconnection.com
The cover on it is now just an all-black cover, iirc it was the lid to a watch box that happen to be clear plastic and fit exactly. I'm thinking about getting that black "mesh" wire loom to clean it up a bit, but I actually like being able to see all the wires, something "Functional" about the look.
Old 12-29-2012, 06:13 AM   #14
68Stepbed
68Stepbed's Avatar
Thanks,
Kevin C
Check out Holley's website. They make some cool compressor mounts. I believe Dirty Dingo also has some compressor relocation brackets.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
