Old 12-23-2012, 03:39 PM   #1
rustyrexiusrodz
do tubular a-arms really warrant the cost?
i want to put tubular a -ams on my truck (1972 c-10 short box) but can't find alot of info on what you gain (performance wise) buy putting them on? and thoughts would be helpful.
olyhotrodz
rustyrexiusrodz is offline   Reply With Quote
Old 12-23-2012, 03:47 PM   #2
Fldawg
Fldawg's Avatar
Re: do tubular a-arms really warrant the cost?
i'm thinking about that now too, besides getting the geometery better on the front end, which allows better front end alignment, i don't know if it's worth the cost.
interested to see everybodys input
Fldawg is offline   Reply With Quote
Old 12-23-2012, 03:52 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Talk to Nate Porter at Porterbuilt.
He has several versions of his control arms.
Definitely a great product!
http://www.porterbuiltfabrication.co...arting-at-1049
http://67-72chevytrucks.com/vboard/s...d.php?t=537266
(plus,... have you priced all the parts to rebuild your stock a-arms?)
Keith
Convert to disc brakes.
Old 12-23-2012, 04:11 PM   #4
Lee H
Lee H's Avatar
If your staying stock or as a stand alone product or miss matched with other things then no, it's not worth the cost. If lowering and as a complete system of matched components then yes, well worth the cost. Much improved steering, suspension, and tires last a lot longer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-23-2012, 04:23 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I agree with this. Unless you are going to upgrade everything along with them it is pointless. Since I do not have $1000's of dollars to spend I just left my stock arms. It is dropped 5-5.5" in the front and I have zero problems with alignment. However the lca hits the ground if I hit a pothole or go too fast over a bump.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-23-2012, 04:36 PM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
If you just want the truck 2-3 inches lower in the front then I would use drop spindles and leave the rest alone. Drop spindles are designed to lower the truck and keep the front suspension geometry stock. When you use stock components, there is a limit to how far the caster, camber and toe can be adjusted and stay with in specs. No matter what, it is about tire wear and the tires ability to make the best contact patch on the road as possible.
TBONE1964 is offline   Reply With Quote
Old 12-23-2012, 05:46 PM   #7
big_al_71
big_al_71's Avatar
When I bagged my truck I switched to tubular control arms upper and lowers....
I felt that they were worth for me to spend the $$$ to compliment the rest of the suspension on my truck.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-23-2012, 11:12 PM   #8
Hart_Rod
Hart_Rod's Avatar
I just installed them on my 68. The reasons I did it, better geometry, less weight and they look way cooler!!!!
Hart_Rod is offline   Reply With Quote
Old 12-23-2012, 11:36 PM   #9
Fldawg
Fldawg's Avatar
rob, which company did you use?
Old 12-23-2012, 11:48 PM   #10
Hart_Rod
Hart_Rod's Avatar
I went with CPP because I still have coil springs in the front.
R/
Old 12-24-2012, 12:16 AM   #11
Square_78
Square_78's Avatar
You definately don't "need" them but they are cool. If I didn't have control arms and needed to buy some then sure, why not. As for advantages over stock, who knows. I've never had a problem aligning my trucks at any height. Longer camber bolts and shims and pie cutting ball joints. It's all easy to do. Tubular arms sure do look cooler though!
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 12-24-2012, 12:23 AM   #12
mooseknuckles
mooseknuckles's Avatar
my christmas gift.....
some info....http://www.ridetech.com/store/1963-1...ont-lower.html
mooseknuckles is offline   Reply With Quote
