12-23-2012, 05:18 PM | #1 |
Dually guys get in here!
Might be picking up a 82 single cab dually shortbed 454 th 400.
The body is rough but seems the running gear is solid. Thinking of just slamming it and stick steel black wheels, shoot it flat black and tint the windows and make a fun cruiser. Is ther a set of steel 17'' dually wheels? Can I make the rear from dually and just put one large wheel and tire on rear? Is it as easy to lower as any other 73-87 chevy? But I wanna make this fun, maybe fast, low and loud! |
12-23-2012, 09:31 PM | #2 |
Re: Dually guys get in here!
Sounds cool, you sgould be able to find a set of 19.5 steelies from a motor home.
John 82 Chevy Silverado 350ci/TH350 |
12-23-2012, 10:54 PM | #3 |
Yes you can get super wide rear rims whatever offset needed in an 8 Lug pattern. Lowering a Dually is as simple as any other 73-87. The only major differance is the rear spring width is narrower than the 1/2 tons, so you can't use the pre made spring hangers.
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-24-2012, 03:46 AM | #4 | |
C35 Crew Dually
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
12-24-2012, 06:47 AM | #5 |
or you can use 22 or 24 inch semi wheels.
you can slam it to the ground, add a big motor and go cruisin.. |
12-24-2012, 08:00 AM | #6 |
^ and spend about 5 times as much on the wheels and tires as you're paying for the truck
I'm building a dually and will have to have custom 16x10s made, I want to keep it dually rather than running a super single. |
12-24-2012, 12:57 PM | #7 |
GoatLube Experss
only 3 times more for the wheels than the truck, but worth it.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
12-24-2012, 06:45 PM | #8 |
Yeah i do not wanna spend a ton of money of wheels. I want steel wheels so i can paint them or aluminum if they are cheap enough. Dont the 19.5's need milled down or something? might just use a stock steel wheel on front and find the big fat wheels i want for the rear!
12-24-2012, 07:15 PM | #9 |
Found my wheels, 15x10 front and 15x14 rear matte black steel wheels!
12-24-2012, 07:21 PM | #10 |
GoatLube Experss
that will look good
12-24-2012, 07:24 PM | #11 |
Here is my 99 with only 24k miles
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
12-24-2012, 07:41 PM | #12 |
12-24-2012, 07:52 PM | #13 |
gets board easy.......
12-24-2012, 08:02 PM | #14 |
I bought it new
12-24-2012, 08:04 PM | #15 |
GoatLube Experss
yes, I have 8 to 10 lug adapter's on it.
01-04-2013, 06:34 PM | #16 |
01-04-2013, 06:38 PM | #17 |
anyone running a super single in the rear? i've always wanted to see em on a lowered square
"As I walk through the valley of rice i fear no honda, for i have torque!" |
