![]() Join Date: Aug 2004
u-joint ?
I need u-joints for my 71 k10 front axle shafts. I looked up moog heavy duty u-joint part# 365 comes up. I went to several companys and part#365 comes up. Here is where I question the part is the right one, I went to the store and the part seems wider than the u-joints that are in my shafts currently. Is it ok for the caps to be less than flush with the axle shaft yokes surface. Any help would pe great. John
Currently Blazerless
Re: u-joint ?
Try a 260x , that should work unless someone has upgraded to the 73 up shafts, then you would need the 297x or the newer version 760x
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 12-23-2012 at 11:10 PM. |
Re: u-joint ?
Thanks BLAZERMAN my son and I just finished removing the old u-joints and now can compare them much eaiser next time to the parts shop. Do you have better success with greasable or non greasable u-joints as far as strength. The shafts are the original 71 spicer shafts. I have the newer shafts that I restored years ago and have been sitting in the corner from a past 79 truck that I compared them to. Thanks
Re: u-joint ?
I checked into the 260x that you suggested and what I'm seeing is the spicer 5-260x, is this what I should be buying? Thanks
Re: u-joint ?
Yes thats the one. I usually go with the non greasable version on axle joints..they are slightly stronger and rarely get greased anyway, almost impossible when installed. Heres a few other numbers that will work if you cant find the Spicer.
Rockwell/Meritor CP260X Neapco 1-0174 Borg Warner 114-573 Borg Warner 114-574 Chrysler 1843143 Chrysler 2409783 Chrysler 3633944 Chrysler 3683980 Ford B9T4635A Ford B9TZ3249A Ford C6TZ3249A 1181735 2403700 2409783 3780158 3981590 Mopar D-50 Precision 356 Precision 365
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
