ran out of money
blinkers for right only
i need some help.. my blinkers work fine, but once i turn on my headlights the left blinker doesn't work the right one does and so do the 4 way flashers, anyone know what could make this happen? thanks for all of your help
Michael
Modify everything, leave nothing alone!~ ![]() ![]() |
Check the wiring on each headlight and turn signal, you might have one crossed... Just a suggestion
72 Custom, 400SB,T400,PS,PB,AC Chesapeake, VA |
Weapons Of Construction
Check your grounds, at the headlight, at the turn signal, and also at the side marker light. The side markers are wired so that they flash with the turn signals, I think. One common place for bad grounds is at the lamp socket itself. If the outer shell of the bulb base isn't well grounded, it won't work right. Usually, you can tweak the sides of the socket in a little and get it to work better. Also, a small wire "bottle brush" works wonders to clean up the sockets and the contacts. Be sure the lights are off though, or you will toast a fuse or the socket.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
