12-24-2012, 08:01 AM | #1 |
4th gear sputtering
Got a weird 1 for y'all. My truck was running like crap so I did some trouble shooting and found you my timing had moved so I redid the timing and it ran great. This morning I drove it to work and when it goes into 4th gear ( 700r4) it's falls on its face completely, it won't rev past 1000 rpm's and will actually cut off.. It doesn't do it everytime also if I restart the truck it will run fine
Posted via Mobile Device |
12-24-2012, 10:00 AM | #2 |
Cluster King
Re: 4th gear sputtering
That could be a number of things based off of what you described. Next time you drive it, try not using 4th gear and see if it does it in third. It sounds like something heat related like an ignition module (if you are running GM HEI) or possibly fuel vapor lock. Does the truck have cat converters? Keep an eye on your temp and oil pressure when this is happening.
You are in good hands. There are a lot of very smart people on these boards and we all are glad to help. This may take some time to narrow down. |
12-24-2012, 10:04 AM | #3 |
can we get more details? any vacuum issues? sounds? strange behavior? if you ride the brake in first can you get the same problem? any gremlins in your wiring?
USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
12-24-2012, 10:48 AM | #4 | |
12-24-2012, 11:44 AM | #5 |
Your fuel pump is going away.
12-24-2012, 11:59 AM | #6 |
12-24-2012, 07:43 PM | #7 |
Update: now it's doing it in all gears and cutting off and very hard to restart
12-30-2012, 06:32 PM | #8 |
Pump took a crap now have a mallory 4110 on order should be here Wednesday
