found this behind the seat of my '67 K-20
http://www.patentsearcher.com/sheet.jpg
The paper was all falling apart, circles are where the coils were contacting it, and the series of holes are where other springs were rubbing it for 45 years. I had it laminated onto a piece of paper. Oilbath Air cleaner. lol Had one of those in my '51. Seriously though, anyone know of a de-coder ring where I can find out what some of these codes mean ? I'm mostly interested in learning the original color of the beast. Box #43 says "color" but only lists the letters T and A. There s the word "ivory" in box 36. Or, is this sheet pretty much worthless ?
'67 K-20 longbed 4X4, 350, SM-420, Vortec heads, flat top 4-brow pistons, Eaton 4.55's, Qjet, MSD 8365, Comp XE250H, Dynomax duals |
![]() Join Date: Oct 2010
Re: found this behind the seat of my '67 K-20
That is the original build sheet. Unless the seat is not original to your truck. Great find. Most are gone by now. It should match to the SPID sheet on the glove box door.
![]() Join Date: Jul 2001
That is your truck's factory Build sheet. It will list all equipment that your truck was built with from the factory. They are a neat piece of documentation to have and fairly rare to be found in our trucks.
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
Active Member
![]() Join Date: Jul 2007
I'd definitely keep it if it's original to the truck otherwise it's just a piece of paper. It would be easy to check.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
yeah, its orig, it matched the SPID data on the glovebox door.
It clearly shows the exterior color as 526 Ivory with a 514 Blue vinyl interior. The Ivory call out in box 36 should be the grill color.
The major options are pretty clear along the bottom. Spare wheel lock Deluxe heater West coast jr mirrors Inside mirror Wood floor bed Locking hubs Oil bath aircleaner Side mount wheel carrier 7.00x16 6 ply tires Full foam seat Gauges (without tach) Ivory exterior (solid) Blue vinyl interior and blue sheetmetal (two shades)
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Where's a picture of the truck?
Here ya go ya ole redneck:
http://www.patentsearcher.com/7.jpg and I ain't never paintin it "Ivory" ![]()
'67 K-20 longbed 4X4, 350, SM-420, Vortec heads, flat top 4-brow pistons, Eaton 4.55's, Qjet, MSD 8365, Comp XE250H, Dynomax duals Last edited by ChrisWhewell; 12-24-2012 at 08:02 PM. |
Too bad the ivory goes very well will the multiple blues of the interior.
![]() Join Date: May 2012
that is really cool that you found that , i bet not many are left..
I guess it doesn't look that bad, thanks for the pic. I'm shy a little on the chrome trim though.
Understand what you are saying about not having chrome. Without the bodyside molding its not too bad, but without the chrome grill surround an ivory truck can be a bit bland. Right now I cannot remember the correct color for the bumper if it is a true white or the ivory color. Below are a couple of pictures showing what I think is an ivory truck with an older "restoration". While not correct it does give a good overall feel. The interior blue is too dark though in the pictures. On a final note the two-tone factory paint used the ivory vs white on the roof.
