Old 12-24-2012, 04:58 PM   #1
Dylan86
Dylan86's Avatar
Cab corner help
Has anyone out there replaced/repaired there cab corners?? any pics, tips or tricks? i have the sectional cab corner replacement pieces, just want a good idea how to do it properly. thanks!
Dylan86 is offline   Reply With Quote
Old 12-24-2012, 06:13 PM   #2
Zebb
Zebb's Avatar
Re: Cab corner help
Best tip I can give you is to make sure you cut all the rust out but don't use the whole replacement panel if it is not needed. Be prepared to find some more rust other than the cab corner skin. You just have to deal with what you find on each particular truck. It's not that hard of a job but you get out of it what you put into it so don't rush it and call it good enough if you want lasting results.
Here are a few pictures. Keep in mind that I'm not a pro by any means.
Here I cut out a cab corner that was hacked in to the cab I bought.
This is the extra rust I had buried under the cab corner.
New inner cab corner piece.
Outer cab corner installed along with a piece of the rocker panel.
Looking at it from the underneath.
Some filler on it and taking shape.
I hope this gives you the info that you needed so you can see what it involved. There are many talented members that can help better than me.
Post up some pictures of what you have to work with.
Zebb is offline   Reply With Quote
Old 12-25-2012, 12:51 AM   #3
andrewmp6
Re: Cab corner help
Hes right cut out all of rust and cut off what you need from the patch and weld it on.When you cut the patch cut it a tiny bit bigger so you can trim it down for the prefect fit.Anyone know why they rust out tho?
andrewmp6 is offline   Reply With Quote
cab, corner, corners
