Old 12-24-2012, 11:47 PM   #1
robert_63
robert_63's Avatar
converting 87 sending unit to braided steel line
Does anyone have any info for going from my factory 87 sending unit out to engine? I plan on trying to use the factory lines from the 5.3 down to the fuel filter then just plumbing from the fuel tank sending unit to the inlet side of the factory fuel filter, and on the return line just jumping from the factory return line to the return inlet on the sending unit. Its either this or just getting fittings to convert the sending unit straight to -6 braided steel lines, any help would be great thanks.
robert_63 is offline   Reply With Quote
Old 12-25-2012, 01:35 AM   #2
mooseknuckles
mooseknuckles's Avatar
Re: converting 87 sending unit to braided steel line
where is the pump?....in the tank?
mooseknuckles is offline   Reply With Quote
Old 12-25-2012, 10:18 AM   #3
robert_63
robert_63's Avatar
Yes im usingthe 87 tank and sending unit with internal pump
Old 12-25-2012, 12:42 PM   #4
bohmankid
bohmankid's Avatar
What kind of pump are you using? Part number? I also want to do what you are.
bohmankid is offline   Reply With Quote
Old 12-25-2012, 01:10 PM   #5
robert_63
robert_63's Avatar
Ac delco ep381
Old 12-25-2012, 06:39 PM   #6
bohmankid
bohmankid's Avatar
And that pump mounts right into the 87 sending unit? Maybe you could fasten a fitting like RUS-640860 onto your sending unit ports? I don't know though, hopefully somebody else can chime in.
Old 12-25-2012, 08:40 PM   #7
robert_63
robert_63's Avatar
yes the pump fits directly to the 87 sending unit just like stock
Old 12-25-2012, 10:59 PM   #8
ls1nova71
ls1nova71's Avatar
Im sure there are other less expensive places to get them... but Street and Performance sells adapters to go from the o ring fittings on the factory sender to AN fittings.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
