Old 12-26-2012, 01:51 PM   #1
68GMC_Dan
68GMC_Dan's Avatar
Power Steering Problem
This may be a little long winded
Removed my AC Compressor (Cut Belt Removed hoses and Compressor).... Power steering stopped working as well??? Bought a new pump , which after Researching Autozone pumps am fairly certain it is bad. Question comes in on the pulley I pressed my old pulley on the new pump and when I turn the wheel I get the screaming , no working power steering (Bad Pump Im assuming) and the pulley seems to move (Alot) and stick while it screams... Any ideas on wtf is going on? Think the pump is bad or did I eff something up?
Its a 77 GMC k1500 400SBC if it matters.
Danny
68GMC_Dan is offline   Reply With Quote
Old 12-26-2012, 03:26 PM   #2
SSC's76
No No
SSC's76's Avatar
its possible it just needs the air bled out. fire it up fill it then turn it left right a few dozen times re check your fluid. if still no go then its a bad pump
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 12-26-2012, 05:26 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Power Steering Problem
You said you pressed the pulley on. Did you press the pulley on or pull it on with a threaded installer of some fashion ? If you literally applied pressure to the pulley until it slid onto the shaft and seated, I can see a problem.
Barring that, it's usually aerated fluid. Sometimes it even takes over night to get it to settle out regardless of how much you cycle the system.
Old 12-26-2012, 05:48 PM   #4
68GMC_Dan
68GMC_Dan's Avatar
I had it up on jack stands and moved the wheels back and forth a few times probably not a few dozen but enough for it to quit bubbling going to try another pump...Think I should I try to air it out some more before I remove it?.... Also installed the pulley using the appropriate tool (borrowed from Oreilys)
Think a bad pump would cause the pulley sticking and moving?
77 GMC K1500 400 SBC TH350 4" Lift Work in progress on the brightside Registered as a Pre Smog 75
2009 GMC Sierra 1500 CC Daily Driver (wife lets me drive every now and then)
Old 12-26-2012, 10:27 PM   #5
SSC's76
No No
SSC's76's Avatar
its possible if you went heat cycle and got most the air out let it sit over night if it still doesent work then I would suggest getting another pump.
