12-26-2012, 03:51 PM | #1 |
dana 70
can anyone tell me if i can use the ring and pinion housing out of a Dana 70 SRW and install it in a Dana 70 DRW ? the reason i ask is that i have a lead on a DRW and SRW but the gears i want are in the SRW, so i want to know if i can just swap center sections or ??
please advise Thanks. Henry.
1964 1 Ton flatbed service truck (sold) 1964 C-10 panel (project complete frame up build) 1957 210 post pearl orange |
12-27-2012, 12:32 AM | #2 |
60-66 Nut
Re: dana 70
As long as both are the standard Dana 70, yes they will interchange. However the gear pattern and backlash will need to be checked when installed in the new housing.
12-27-2012, 08:06 AM | #3 |
Re: dana 70
thanks, now even if i take the third member out and swap it with the gears installed would i still have to check back lash , i would think not but then i'm not the rear end guy,
thanks John.
12-27-2012, 08:26 AM | #4 |
Re: dana 70
Yes, anytime you disassemble a differential, you need to reset the backlash on the gears.
12-28-2012, 02:08 AM | #5 |
60-66 Nut
Re: dana 70
Yes, just as tincan1966 said. Anytime you remove the carrier and ring gear and the pinion and install them in a different housing, everything needs checked again. Once in a while you get lucky and they don't need adjustments, but they do need to be checked.
