66 c10 factory color and beauty rings
Just picked up a 66 c10 fleetside longbed.
It its light blue with some patina. Does anyone know what the factory blue paint was called? Also, will any 15" beauty ring fit these stock wheels? Thanks, Joe Posted via Mobile Device |
Re: 66 c10 factory color and beauty rings
If you use the search feature it will help you a ton.
Senior Enthusiast
Welcome to the forum. Here’s a link to an easy to use color library:
http://www.tcpglobal.com/autocolorlibrary/ Just type in Chevy Truck and 1966 and you should end up at this page showing the various 1966 colors offered: http://www.tcpglobal.com/aclchip.asp...truck-pg01.jpg The early 40’s-50’s style hot rod trim rings will fit just fine. Later 1960’s designs (like Corvette for example) probably won’t because the rings are deeper than the face of the wheels. It’s a trial and error process, or ask around at the next rod run when you see something you like on a car or truck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#4 | |
![]() Join Date: Aug 2010
When I bought my Suburban it had like new beauty rings installed on the stock 15" wheels. Taking them off was the very first thing I did to the truck after it became mine. I'm not sure if these were available as an accessory in those years or not. |
awesome!
thanks for the help and the warm welcome I really appreciate it. sorry for the newb question ha Posted via Mobile Device |
Post photos of your truck we all want to see..........
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
sorry 2 are sideways. I was uploading from my phone and it wasn't cooperating.
and the shag carpet on the door was there when I got it haha Posted via Mobile Device |
![]() ![]() Thats a Great old truck
Thanks!
This was it when I first got it. I painted the top white and took a grinder to those thin whitewalls I picked it up for 2,000 about 50 miles from where I live and was able to drive it home. Stock 250 3 speed on column. I had to replace the carrier bearing on the 2 piece drive shaft right after I got it. And I still need to throw on the new valve cover gasket I have because its leaking from the old one. Other than that it is a mechanically sound truck and not rusted into pieces like most of these NC trucks are. I think I made out pretty well for 2,000 Posted via Mobile Device |
Nice score...........Thats a easy 2 grand truck . your going to have fun with it
