bed wood without metal strips anyone done it?
getting ready to redo the bed wood in a 67 .looking for pics of beds with out the metal strips.I dont mean just covered with ply wood. not looking for lessons on how wood expands and that is why the metal is there .I know how to deal with that. just wanted to see if any one else has done this.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: bed wood without metal strips anyone done it?
Should be pictures on Mar-Ks website. They sell a kit that has hidden strips. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
![]() Join Date: Nov 2004
Are you looking for something cheap? I used treated deck boards for my bed. No strips.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
I'm in the middle of doing my bed and I haven't decided how I am going to do mine. I am leaning towards doing it without the strips for a cleaner look. I am thinking I would have to drill some extra holes in the cross sills and run short screws up from under the truck bed and just have only the perimeter bolts showing.
I am buying the wood from a local lumberyard and milling it down to fit.
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
![]() Join Date: Oct 2012
#6 | |
Here is a bed I found looking for Longhorns. Really can't see the benefit of eliminating the strips they do a lot to tie the bed together.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
In my opinion, a bed with out strips is going to be a large bland panel with out contrast to break it up.
If you want to do something different, make strips out of Ebony, or some other different shade of wood. Or you could do what I'm doing.............. my two cents.............
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ Last edited by biggestjohn; 12-27-2012 at 02:25 PM. Reason: tease |
my two cents.............[/QUOTE] what are you doing? |
Kill Bill...et
Subscribing. I too like the rough look without bed strips and was planning on doing the same thing on a two inch raised bed. I also wanted to somehow add a piano hinge across so I could lift a section up to access the air ride stuff underneath. I thought of adding three or four aluminum strips across the bottom to tie everything in but am worried about dirt and gunk building up on top of them. I never thought of the wood expanding and contracting, but the porch I built off the back of my house hasn’t buckled yet and it’s pretty well secured.
#12 | |
#13 |
Kill Bill...et
So how do strips differ from just having a gap in the planks?
#14 | |
Doing away with the strips will require an alternate method of board retention to cope with thermal and moisture related expansion activity. In addition spreading the loads to adjacent boards to reduce point loading needs to be addressed. Plus this method must locate the boards to keep the bed square and firmly attached to the chassis during torsion, positive and negative loadings.
#15 | |
Instead of doing slotted holes I may just drill the holes just large enough to allow movement without the screw head pulling through. It's not really surrounded by steel, there is a gap between the end of the cross members and the outside side wall of the bed. The front panel of the bed isn't all that stout, the rear crossmember is the most rigid. I think if the boards are tongue and groove I think they will work together to distribute the load weight. Also, I wouldn't jam them together to tight, maybe leave them a little loose to help with expansion and contraction. my two cents!
#16 | |
#17 |
I'm leaning back to oak, I found 4 boards up in my barn loft today. They are left over from some job I must have done a few years ago.
