![]() Join Date: Jan 2011
McGaughys 4 wheel disc question
Some of the guys running the McGaughys 4 wheel disc kit .. Are your wheel studs a little short? Have you replaced them and if so, which part number did you use? I'd say I need about another 3/8".. (6 more threads or so ? )
The ones I have give me maybe 5-6 threads I'd just like to get a little more .. Is there a car out there running 1/2 20 like this we could cross reference? thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
![]() Join Date: Feb 2001
Re: McGaughys 4 wheel disc question
I don't know if you will find the answers in these threads but I thought I would post this for you.
McGaughys 13" Front Brake Kit Interchange Parts http://67-72chevytrucks.com/vboard/s...d.php?t=462680
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 12-27-2012 at 09:54 AM. |
A day late and $1 short...
Hey Chad, gringoloco's build thread covers this I'm pretty sure. -Buck
Posted via Mobile Device http://67-72chevytrucks.com/vboard/s...d.php?t=444746 post #980
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 12-27-2012 at 08:44 AM. |
70cst can you edit your post to correct the link for the rear brake thread? You double dipped on the http// so it redirects as an invalid URL.
Thanks For some reason I can't LINK these up Last edited by 70cst; 12-27-2012 at 09:55 AM. |
OK, so I get this right the McGaughys 13" fronts are '96 C4 Corvette Gran Sport rotors with 2000 Silverado Single piston sliding calipers? ...and the 13" rears are also off the shelf GM rotors and calipers of some sort? ...and have integrated parking brake? I know when I called CPP they claim that you have to get the rotors from them, special some how, I'd really like to get brakes where I have more rotor choices and not be at the mercy of having to get replacement parts for some specific kit. If that means converting to 5 on 4 3/4 on all 4 corners, I'm OK with that. I'd rather spend a couple hundred on a pair of axles then be stuck without a rotor supplier 5 to 10 years out.
#7 | |
You're really really close .. ![]() Front calipers are 2000 Silverado dual piston. I saw a Trailblazer (not an SS) this morning and the calipers looked a lot like the ones I have in my kit. I took them apart to paint them., they looked really familiar. The rotors are 96 Grand Sport. McGaughys offers a drilled upgrade, I'm not sure about them but so far so good .. (mine are drilled) I haven't run them yet. I'm not sure what the rear calipers are from, but they are single piston. Integrated parking brake that likes to pinch fingers. ![]() My only complaint with the kit the instruction are not really clear on how to mount the rear caliper brackets. It took me a couple times to get it right. Also they will take some minor shimming to get them perfect. Add a washer between the bracket here and there to shim it perfectly. (most kits will be no different) The wheel studs in this kit could be a touch longer.. not a complaint .. If I had different wheels, it might be fine. Other than that, man .. get it. It's the best kit for the money IMO. Summit carries their parts too. Just take the McGaughy's part number and plug it into the Summit 'search' box and it will come right up. If I had it to do over, I'd get the same kit. I have their drop spindles too on both my trucks. .. I really like their stuff. But really, check with Travis or someone here on the site if you have cash they might be able to save you some money. I am going with a Wilwood MC, 1 1/8 bore and an adjustable Wilwood proportioning valve.
