![]() Join Date: Dec 2012
Has anyone replaced 70 3/4 ton rear wheel studs with 9/16?
Hi.
I have a 70 3/4 ton with free floating rear axle and am replacing front drums with disc. The front disc have 9/16" studs. Are there REAR studs that are 9/16" that are press in for the ones in there now?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Re: Has anyone replaced 70 3/4 ton rear wheel studs with 9/16?
Davepl modified his Longhorn to 9/16" studs for the same reason.
http://67-72chevytrucks.com/vboard/s...d.php?t=543067
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thanks. My search didn't return any results. I must not have spelled correctly.
I did this on all four corners on a '70 CST/30 I had that I put chrome Budds on,since those were all made for later disc brake trucks. Just be sure to drill undersized so the stud splines will "cut" themselves in when pressed in.
I have a 1970 dana 60. I drilled out the hub and pressed in 9/16. I think in 71 they changed to the 9/16.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#6 | |
Maybe I'll just live with 1/2 on the rear for now. Maybe put disc on the rear later. I don't trust myself with a hand drill and I have given my drill press away. OR I guess I could find another drill press and resell on CL when I am done with it.
You don't need a drill press. Here is a link for studs. https://www.dormanproducts.com/catal...ec10_Part4.pdf
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Thanks!! I'll remove one of the rears and find one with the knurl and length that is close. That really helps.
Thanks again.
You can go to autozone , use truck info and they list the 2 studs with all info per coil or leaf springs. That way you don't have to remove the stud to check.
