![]() Join Date: Mar 2004
how to tell difference in tops???
Question on single wall and double wall tops.
How can you tell from pictures? What are the pros and cons of either of the two? Some may say do a search, but the Captain in me thinks that is too many steps! ![]()
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
![]() Join Date: Jan 2001
Re: how to tell difference in tops???
If the pictures are only of the outside, I'm not sure you can tell very easily. The interior is pretty easy. The double wall has ribs in the top and the single wall doesn't. The single wall you can see the lip at the bottom where the bolts go through; the double wall is smooth to the bottom. The single wall also has two dome lights on the driver's side, although I've heard of at least one double wall that has the dome lights as well.
Weight is a difference for one. The single wall top bolts from the top down and double wall bolts from the bottom up. Single walls have lights and very few double walls have lights mounted according to some forum members who have a double wall with lights. I have never seen one though.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
Single wall 350 lbs double wall 450 lbs........ I do own a black double wall with dome lights
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400 64 C10 SWB 406SB TH400 74 SUBURBAN 454BB TH400 78 K10 SWB 350 TH350 6" ON 35" BFG MUD 71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD 00 K3500 DRW BIG BLOCK "DRINKING PRBLM" |
#6 | |
