![]() Join Date: Nov 2011
best degreaser
About to pull the motor out of my 80 k20, its a nice oily mess. What are everyones preferences for decreasing motors and oily greasy trucks, I have a pressure washer, but the weather is in the 30's, any recommendations for a faster cleaning and less chance of frostbite?
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
Re: best degreaser
Gloves and a pressure washer. Engine degreaser from a parts store. About two cans will do spray it and scrape it. Spray it clean then brush it spay it clean and let it sit between steps.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
At the body shop.
Re: best degreaser
Simple green or purple power.
" That didnt make it any newer " " Dont antique the equipment " |
Re: best degreaser
None of the degreasers are going to work very good when they're cold.
Put the engine in the warmest spot you have, remove any plastic stuff on the engine and dig off all the crusty stuff you can get to. Spray it down good with some oven cleaner (generic is just as good as name-brand), use a whole can. Let it set awhile, then hook your pressure washer to the drain line on your water heater so you have hot water to wash it with. Hot water helps to melt the grease, makes an amazing difference. |
#5 | |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: best degreaser
But don't breathe it. ![]()
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... Last edited by ETsC10; 01-10-2013 at 08:56 AM. |
Re: best degreaser
Yeah, or get it on your skin, it's lye!
And keep in mind that the more you're able to get off before you spray it down, the better it'll work, regardless of the degreaser you choose. Scrapers, screwdrivers, etc., are your friend, work at it until you get everything off that you can, then use the degreaser. |
Re: best degreaser
wear rubber gloves and eye protection if you go the oven cleaner route. trust me it will melt your skin and burn. it does work well and the hot water tank what great idea.
Posted via Mobile Device |
Re: best degreaser
Thanks everyone for the input, would like to do use the hot water solution, unfortunately can't because to because hot water heater is in hall closet with no drain if hose were to leak, thinking oven cleaner will do the trick with goggles, and gloves.
Re: best degreaser
I know you already thought of this. any faucet that has hot h2o.
![]() Join Date: Oct 2006
Re: best degreaser
Usually the washing machine will have a hot water spicket.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Re: best degreaser
It's in the hall.closet as well
I am a Referee of life.
Re: best degreaser
Don't use water over about 120*.I believe it's actually 160 the manufacturers recommend staying under but I prefer a good margin of error.The seals in most pressure washers will deteriorate after a certain temp.So much so that heated pressure washers all pressurize the water before heating it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#13 |
Re: best degreaser
dollar store, mean green [simple green just cheaper]
#14 |
Re: best degreaser
I second oven cleaner, it will work great. Be VERY careful like others said. On my truck I sprayed oven cleaner on a suspension part, and started scrubing with a brush without eye protection. The next thing I know, the bristled fling quite a bit of oven cleaner in both eyes. It burned extremely bad and I had to find my way into the house, got into the shower and started blinking my eyes under the water for about twenty minutes. That sucked!
#15 |
Re: best degreaser
dude can you see? it must have felt like you put gas on your eyes and fired them up! OUCH!
#16 |
Re: best degreaser
My friend Chris @ Chicken City Hotrods was using kerosene the other day when I went by his shop. It smells just like Gunk Engine Degreaser. Coincidence I think not.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
#17 |
Hand Crafted C-10
Re: best degreaser
Unless you are breaking down the engine for rebuild and, instead, plan on touch-up paint after cleaning, you will get far better/long lasting results if you re-clean the engine with soap and rinse with water prior to paint.
Also, it seems a no-brainer but make sure your runoff from the de-greasing isn't washing into a storm drain or stream. Generally, storm water goes directly into local waterways and aquifers (your drinking water). I hire out to mega-detail a few engines & engine bays each year and when I can't take the motor to the car wash (for the above reasons), I scrape first, hand-clean using mineral spirits (works the same as eldogg's kerosene) and a scrub brush followed with carb cleaner or lacquer thinner and clean rags until the surfaces are paint ready. Unless the motor's going into a freshly done truck, this is also a perfect time (while the engines out of your way) to really clean the engine bay, cross member & core support, attend to messy wiring, etc. My 22 cents worth... ![]() |
#18 | |
Re: best degreaser
then have a squeeze bottle to force the hot water rinse. Won't be much force but better than pouring it and more control.
"I feel the need for speed!"... as soon as I am done with my nap. |
#19 |
![]() Join Date: Jun 2012
Re: best degreaser
POR's Marine Clean. The best degreaser that I have ever seen. Just make sure you wear rubber gloves.
#20 |
Re: best degreaser
I have a commercial supply truck that brings stuff to the shop. The stuuff I get is called Oil Eater. Not sure if it is available to the general public but it is hands down the very best degreaser I have ever used.
#21 |
![]() Join Date: Jul 2012
Re: best degreaser
I'm having really good luck with the Marine Clean and a pressure washer. Putty knife to get off the clumps, soak it down with the Marine Clean, power wash, let it dry, then get whatever is left with a wire brush.
#22 | ||
Hand Crafted C-10
Re: best degreaser
![]() Good suggestion! Oil Eater does work well and is fairly pleasant to work around. Around here, it is available at any of the auto parts stores. .
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
#23 | ||
Hand Crafted C-10
Re: best degreaser
I used to use bilge cleaner for everything (ran out of it) and it worked better than anything plus is biodegradable. Quote:
![]() Good suggestion! Oil Eater does work well and is fairly pleasant to work around. At least around here, it's readily available at the parts stores. .
#24 |
Re: best degreaser
X2 on Marine Clean. It works best when hot. I have a hotplate in my shop, I heat a pan of water and put the spray bottle in it to heat up the Marine Clean. I loosen the spray head so that the expanding air can get out as it warms up.
#25 |
![]() Join Date: Jun 2006
Re: best degreaser
It is and I love it too.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
