12-27-2012, 03:06 AM | #1 |
Am I screwed?
Trying to install cpp 5 lug axles and I found this. I believe this is supposed to be longer than this. I think previous owner broke it off. What do I do?
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
12-27-2012, 03:29 AM | #2 |
Re: Am I screwed?
post a pic of what you are talking about
12-27-2012, 03:29 AM | #3 |
Re: Am I screwed?
Sorry! Here are the pics! I have no idea why my pics are sideways!
12-27-2012, 03:39 AM | #4 |
Re: Am I screwed?
if its broke off inside you may have to drill it out that would be my first thought
12-27-2012, 03:45 AM | #5 |
Re: Am I screwed?
Yeah, its pretty far in there! This sucks!
12-27-2012, 07:14 AM | #6 |
Re: Am I screwed?
This has been on the forum before , search it .. But that being said I have had the same thing happen and I resorted to a long brass drift and a very big hammer ,I just drove mine through ,it was pretty simple to shear the pin off with a good hamer , then the pieces pretty much tapped out with a hammer ...........
12-27-2012, 08:03 AM | #7 |
Re: Am I screwed?
The few times I've run across this, I was able to extract the remaining bolt part using a left-handed drill bit(bought mine thru Snap-On Tools)and a small air drill. Once you start drilling, if the bolt is not cross threaded it'll back out.
12-27-2012, 12:12 PM | #8 |
Re: Am I screwed?
Thanks Tincan!
12-27-2012, 09:57 PM | #9 |
Re: Am I screwed?
LMAO I laughed so hard when I seen this, I am not sure if I should tell him to just use mine. It looks so deep and I did not see any way to get a drill in there. I should not laugh the longer you take to get this done the longer I have to work out in the cold.
12-28-2012, 02:01 AM | #10 |
60-66 Nut
Re: Am I screwed?
There is a company that makes a kit for extracting that broken bolt. I can't find the name of the company atm, but it was posted on here not long ago.
Have you tried using a magnet?
12-28-2012, 03:14 AM | #11 |
Re: Am I screwed?
Yeah I was hoping someone would say you took out the wrong bolt or thats what thats supposed to look like, or even a cool little trick to get it out haha. Wishful thinking!
12-28-2012, 06:42 PM | #12 |
Re: Am I screwed?
Is this the kit u were talking about?
Sam >> http://www.matcotools.com/Catalog/to...&page=2稹 << >> http://www.matcotools.com/Catalog/se...bolt+extractor << Last edited by luvbowties; 12-28-2012 at 06:45 PM. Reason: added addy |
12-29-2012, 01:12 AM | #13 |
60-66 Nut
Re: Am I screwed?
Here you go.......
Amazon.com: Differential Pinion Shaft Lock Bolt... Here are the guys that make it...... http://www.fabbriassociates.com/kitinfo.html
12-29-2012, 07:30 AM | #14 | |
Re: Am I screwed?
I ordered one just to add to the toolbox- I know I'll need it!. Beats my method! |
12-29-2012, 11:13 AM | #15 |
Re: Am I screwed?
I had one where the bolt came out but the pin would not. I beat on it with a 10# sledge and finally gave up and scrapped the rear end as I had another. It was all burnt and obviously destroyed anyways.
