Old 12-27-2012, 09:37 AM   #1
twich3136
twich3136's Avatar
modern leafs from a new chevy
has anyone ever tried to mount a leaf with overload from a new chevy to their old 67-72? i want to lift my longhorn and convert to 4wd but i dont want to lose the ride OR load capacity. my brother has an 07 silverado and i was wondering if i might be able to use those on my truck. ive even thought about using the axle and trans from a wreck. metal is metal so modifications can happen if and WHEN they need to lol. but i need input before i take this challenge. anyone taken the challenge?
USMC
SEMPER FI
68 Chevy Longhorn 350/400 factory posi
twich3136 is offline   Reply With Quote
Old 12-29-2012, 12:39 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: modern leafs from a new chevy
Anyone?
Keith
Convert to disc brakes.
Old 01-06-2013, 07:15 AM   #3
twich3136
twich3136's Avatar
ttt- anyone know?
USMC
SEMPER FI
Old 01-06-2013, 11:44 AM   #4
duallyjams
duallyjams's Avatar
Yes you can. A lot of people use the spring for there 4x4 for off road , the 63" spring give a lot better flex and I have also read that the longer spring improves the ride , most people swap over the frame / spring hangers with the spring.
Thank you for your service to our country.
Think maybe you should search in the 4x4 section and check the 60-66 forum for some conversion threads
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-15-2013, 05:23 AM   #5
twich3136
twich3136's Avatar
thanks you. im more looking for a smoother ride and a bit of a lift without loosing the ability to load it up with dirtbikes and a trailer. right now i have the 8/1 springs which hold fine but when i swap to leafs up front ill need to raise the back a bit. the springs my brothers 08 has are 5/1 + 2 helpers on top. i guess ill have to fab up some helper stops somehow because i cant find any kits. ill hit up that other section and continue my research on converting to leafs up front in the mean time. thanks for the in put
USMC
SEMPER FI
Old 01-17-2013, 01:00 AM   #6
Mike C
Mike C's Avatar
Go to 56" eye-to-eye leafs from an 80's 3/4 ton Suburban along with a shackle reversal from someone like Off Road Designs. This will be the easiest way to do what you want. Consider adding airbags for increased payload capabilities.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
