K10 Tie rod help...
I'm having a bit of trouble locating a tie rod adjustment sleeve (wheel to wheel) for my 72 K10. The tie rod ends are easy enough to find, but no listing for the long sleeve. I had a little trouble with a chain and pulling my wife's car out of a snow bank, now I've got a bit of a major "toe in".....
Is there any interchangeable listings? Or am I gonna have to hit the parts board? Thanx |
The Few, The Proud
![]() Join Date: Jun 2007
Re: K10 Tie rod help...
It's not reproduced. You'll have to find an OE used one.
Shannon |
Has anyone ever had one made? Could a good machine shop produce one? Could the old one be straightened?
Yes one could make one from Dom tube, any machine shop can tap the threads for the stock rod ends. I do them all the time in 1.5 x 2.50 wall but that's over kill for what you need.
You could try to have it straighten but depends on how bad. If it's real bad wouldn't even try it.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Napa has a listing for the tie rod bar RPC 27644
i picked up a used one off a 78' Blazer and it bolted right on. also OFF-ROAD DESIGN sells a heavy duty replacement.
Thank you. I had a friend with an exhaust bender fix up the slight bend I had to get me through,but this info is handy for replacing in warmer weather....
