Old 12-28-2012, 02:30 AM   #1
WIDESIDE72
WIDESIDE72's Avatar
What's the deal with sbc water pumps cracking/ breaking at the heater hose port???
I thought I was the only one with this problem on a swp, but tonight I was looking at two other builds and see this has happened to others as well (gringoloco and thelonerife). I knew I didn't overtighten mine either. I guess it just goes to prove that new parts do not equal good parts.
WIDESIDE72 is offline   Reply With Quote
Old 12-28-2012, 02:38 AM   #2
Xeen
Xeen's Avatar
Re: What's the deal with sbc water pumps cracking/ breaking at the heater hose port?
Well you can always weld a rib to the next one to make sure it doesnt break off <cringe>
Sorry about your bad luck with the water pump, but hey on the bright side atleast it can be exchanged.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 12-28-2012, 03:01 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
What stinks is all three of us painted and installed the dang junk, only to have to repeat the process!
I would advise anyone replacing a pump to install the hose nipple FIRST before painting or installing the pump!
Old 12-28-2012, 03:41 PM   #4
chopnchaneled
chopnchaneled's Avatar
Note to self,,,,,,,,,, do what wideside said.
thanks
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 12-29-2012, 03:55 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
thanks
Now if I could just get my wife to do that...
Old 12-30-2012, 04:20 AM   #6
thelonerife
thelonerife's Avatar
Also look at the hole on the side for the heater hose for a ''thin casting around the hole'' before you leave the parts house. I didn't notice it till the piece was on the floor.
thelonerife is offline   Reply With Quote
Old 01-20-2013, 10:33 PM   #7
thelonerife
The 3rd new one cracked also. Didn't know it till I put anti freeze in. Thought it was the hose clamp. After it started, it leaked more. I looked closer with a light and found it. So no more cast wp's for me. Ordering this one.
http://www.jegs.com/i/Weiand/925/9208/10002/-1
