My truck is s 250 3 speed ad i want a better hiway gear.... Whats my best financial route? I want 3:08's
Posted via Mobile Device |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Did all 66 Chev c10's have 4:11 gears?
No not all '66's had 4.10 gears. Although I have seen a couple 6cyl trucks that did. In my experience, most of the C10's had 3.73's. Your most cost effective way to get 3.07 gears is to find a complete rear differential from a '65-'72 C10 with trailing arms and coils. That is assuming your truck has trailing arms and coils.
#3 | |
1. current engine, engine you are thinking of changing to.... 2. transmission you have now and trans you want to run later 3. height of rear tire from ground to top of tire of the tires you have now 4. same info for tires you might change to. I will send you a spreadsheet that shows speed, and torque for all combinations you say you need. Kieth We have to be careful, the speed line may look great but the usable torque may make the truck unable to get out of its own way in 3rd gear....usually folks decide to change the transmission out along with the rear end to make the truck a nice highway cruiser........(low rpms) |
#4 | |
A later model 5 speed trans is sometimes a better upgrade than the rear gears. |
#5 | |
im running a stock 250, stock 3speed on column, 215 70 15 tires, I do alot of highway driving and im gettin like 13 mpg.dont really want the expense of changing a complete transmission and driveshaft.if i could get 16 or so mpg i would be happy the rear end gear seemed like the logical choice in regard to expense.
#7 | |
Here is the info I came up with : 3.08 gears 24" tires ---2000rpm 46.5mph, 2500rpm 57mph, 3000rpm 70mph 28" tires 2000rpm 54mph, 2500rpm 67mph, 3000rpm 81mph 30" tires 2000rpm 58mph, 2500rpm 73mph, 3000rpm 87mph The tire diameter can be just like a gear set change.....Your 250 will be ok, the torque does not fall off that much....Kieth but as you try to go faster on a windy day you will be able to tell that it does not have much umph but your fuel mileage should be better if you will cruise at about 65mph. |
Thanks, 3:08 looks like the ticket
Looks like 3:08 is the way to go
do you have the same equation stats based on my current 4:11 rear?
Go to Randys Ring and Pinion - there is a rpm, speed calculator.( has a online calculator program -free) You can play with the tranny options , gear ratio, tire height , and other stuff - give it a try .
LMD Last edited by lmdangerous; 12-30-2012 at 10:09 PM. Reason: spelling |
Thx
