Old 12-28-2012, 09:07 AM   #1
klutz51
bear claw latches
i am looking to install bear claw latches, does anyone know if i should use small medium or large? any help would be great.
klutz51 is offline   Reply With Quote
Old 12-28-2012, 11:10 AM   #2
Chevette
Chevette's Avatar
Re: bear claw latches
Use the large ones. They are double clasp. The small ones are single.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 12-28-2012, 01:01 PM   #3
klutz51
Thumbs up Re: bear claw latches
thanks for the info i kinda thought bigger would be better but you never know. thanks again
Old 12-28-2012, 01:41 PM   #4
Hogsophist
If I was going to remove the vent window for a single window conversion (power), should i go with the smaller ones for clearance issues?
I have a thread subscribed somewhere that talks about it.
Hogsophist is offline   Reply With Quote
Old 12-28-2012, 03:50 PM   #5
_Ogre
_Ogre's Avatar
hopefully you are shaving the door handles, bearclaws don't have a locking mechanism or an easy way to hook up door handles.
my 58 doors are shaved, i installed new factory latches, no fabrication required.
easy peasy
shop air compressor timer
Old 12-28-2012, 06:13 PM   #6
Coach529
Coach529's Avatar
I bought a set of large latches off a guy over at HAMB.....but am going to sell them because of no way to lock them with handles.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 12-28-2012, 06:59 PM   #7
smittster
i used the company for the made to fit ones from Trique Manufacturing. They can be locked with the original lock. I have a 1950.
smittster is offline   Reply With Quote
Old 12-28-2012, 07:33 PM   #8
48 pickup
48 pickup's Avatar
Has anybody used these,they look pretty good ,first saw them on you tube
Was thinking of getting some ,any thoughts
http://www.hotrodhotline.com/pr/2010...dShop10222010/
48 pickup is offline   Reply With Quote
Old 12-28-2012, 07:37 PM   #9
Coach529
Coach529's Avatar
That is the Trique kit.
1949 Chevy 3600
Old 12-28-2012, 08:03 PM   #10
booger1949
bear claw makes a period correct door latch that lets u use both inside an out side door handles, i have them on my 49 an they work great, the one thing i would recommend is turning your inside door mechanisim upside down an that puts your rod in the channel like chevy should have done in the beginning, an your door panels want b in the way, the only down side is your inside handles dont lock the doors anymore, so im just goin to put electric locks on mine,
booger1949 is offline   Reply With Quote
Old 12-28-2012, 08:05 PM   #11
booger1949
if u use a electric selenoid on the latches u have no problum then, u can lock an unlock it by push button, an the door handles fit mine perfect
