Just like to part out trucks!!
Will a 72 window reg, work in 67-71 doors?
Thats the question I need answered. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
they will work but you know that 72 regulators stick out futher because of the plastic door skins.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
![]() Join Date: Apr 2000
if you need some 67-71 regulaters let huck know, he just got a ton of them,i`m sure he would make you a great deal....
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
Hey Randy, What Rod said. The regulators are specific to the panels for 72. 71 back are the same because of the flat panels, plastic or steel. Do you need a 71 back? I have one but don't remember which side. Sending you a PM also.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide Last edited by nu2-72; 06-07-2003 at 10:29 PM. |
Thanks guys I thought that was the only difference, I got a 72 one on Ebay and said it would fit 67-71, now a guy emailed and told me I was full of it that it wouldn't. I wanted to clarify before I email him back. Thanks Randy
I too need a left side window regulator. Who is Huck?
Thanks Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!" - 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM" - 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL" - 1982 Chev C-10 swb/step 250 I-6 3 spd - - 2001 Chev Silverado LT - |
![]() Join Date: Mar 2000
I took one of these apart one time and I figure if the actual shaft is the only different part then you could probably drill out the rivets that hold the cover onto the shaft and drive gear housing and swap the shorter shaft from a worn out unit ( it's actually seperate from the drive gear) then just rivet or bolt back together. I haven't tried it yet myself but I suspect it would work.
Oh yes there is some real spring load on these things so watch your fingers if you try taking one apart. Don't get em in the wrong place at the wrong time.
Saskatoon, Saskatchewan Canada |
Huck is a member of the board. Bagdad, Ky if I recall corectly. Long time member.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
